Question about Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus CX5000 InkJet pages blank
I put new set of ink cartridges in printer and printing turns out blank. Machine is a little over 1 yr.
أريد فلاش الطابعة
Posted on Oct 17, 2008
I have an epson stylus NX100 and i just put brand new black ink in it recently i printed two pages max i went back to use it and it says that my black ink has expanded and i have to buy a new one? what...
***hi there,ill be willing to help you on that. ****
try to reseat the cartridges first to charge it again, reseat means Remove and reInstall the Cartridges. after doing that and still the same issue, and you have an extra set, try to load another brand new ink,just to isolate if it is the ink thats causing the problem, if the same issue persist, its not the ink that you bought, its the printer already, the printer is broken, call epson if it is still covered by 1 yr warranty, 1 yr with in date of purchase. they will send you a replacement printer.
1. Turn on the Epson Stylus NX100 Series.
If a cartridge is expended, the ink light on the control panel stays on. You must replace the cartridge to be able to print.
If the ink light is flashing, a cartridge is low on ink; replacement is recommended.
2. Open the scanner and prop it up with its support
3. Press the nx100_tx100_ug.1.93.5.jpg Stop button. The print head moves to the nx100_tx100_ug.1.93.6.jpg position to indicate which cartridge is low or expended.
4. Press the nx100_tx100_ug.1.93.8.jpg Stop button again. If another cartridge is low or expended, it moves to the nx100_tx100_ug.1.93.9.jpg position. Press the nx100_tx100_ug.1.93.10.jpg Stop button again to see if more cartridges are expended. If no other cartridges are low or expended, the print head moves to the replacement position on the right. 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
7Remove the cartridge from the package
8. Remove the yellow tape from the bottom of the cartridge.
9. reInsert the new cartridge into the holder and push it down until it clicks into place. 10. Once you replace all the necessary cartridges, lift the scanner slightly, release its support, and lower the scanner.. 11. Press the nx100_tx100_ug.1.93.18.jpg Stop button to begin charging the ink. This takes about 1 1/2 minutes. When the nx100_tx100_ug.1.93.19.jpg On light stops flashing and remains on, ink charging is finished. Caution:
Never turn off the Epson Stylus NX100 Series while ink is charging or you’ll waste ink.
Jan 21, 2010 | Epson Stylus NX100 InkJet Printer
How to change ink cartridges on Epson Stylus CX6600
i just buy new cartridge ink for my epson stylus 4100 and when i print out didnt print its only a blank page what should i do
Dec 04, 2009 | Epson Stylus CX6600 All-In-One InkJet...
The printer is only printing in two colors and only in lines going across the page. not a full print
Make sure that the ink you have, is Epson Ink.
I bought a compatible, supposely ink, and when I put it in, Colors did not come out the same. Lines and words, did not print out properly.
So I threw the ink cartridges, and bought original, Epson Ink, and Ooh-LA-LA, Printed out just fine.
Go Figure.
Good Luck
Nov 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Espon cx5000 printing problem
Try to reinstall your printer.
Check if you have installed the ink cartridge properly.
Clean your print head.
Make sure you are installing a original Epson ink cartridge and not just a refill ink.
Sep 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
My Epson stylus 84 color printer is only printer the color blue
Hope you have installed a original ink.
Take the cartridge out, wipe the extra ink on the cartridge and carrier with little alchole and cotton. and reinstall the cartridge back.
Print a test page and let me know
Kevin
Apr 06, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Printer won't print black color
Really silly I suppose, but...did you remove the protective tape from the cartridge?
Feb 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Prints blank pages
make sure u have the printing options from printer settings set to black only and not colour..
Sep 09, 2008 | Epson Stylus 880 InkJet Color Printer
Epson stylus cx5000 series
i cleaned the post where the ink cartridge slides down on with alcohol. they could maybe be called the print heads i am not sure. but it is for sure this model cx5000 loves ink!
Aug 18, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus  CX5000 InkJet Photo Printer Logo
178 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
