Maytag MMC5000 Microwave Oven Logo
Posted on Oct 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag microwave Probem is intermitant. After entering cooking instructions there is a 2-4 second delay after pushing the start button. Sometimes the input will not display on screen or it will take 2 or 3 attempts to register the cooking instructions. Sometimes the light and exaust fan will not turn on or it may again take two or three attempts. Thanks for any sugggeastions
William Miller
Level 3:
  • Maytag Master 9,179 Answers
  • Posted on Oct 17, 2008
William Miller
Maytag Master
Level 3:
Answers
9179
Questions
Helped
4481517
Points
21747
Your membrane keypad is failing.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
How do I change the power level?
This is from Page 16 in the users manual...
For simple, one-stage cooking, you only need to set the cooking time. The power level is automatically set to High.
If you want to set the power level to any other level, use the Power Level button.
1. Use the number buttons to set a cooking time. You can enter a time from one second to 99 minutes and 99 seconds. To select a time greater than one minute, enter the seconds too. (For example, to set a cooking time of 20 minutes, enter 2, 0, 0, 0.)
2. If you want to set the power level to a level other than High, press the Power Level button, and then use the number buttons to enter the power level.
3. Press the ENTER/START button to begin cooking. If you want to change the power level, press the STOP/ CLEAR button before you press the ENTER/START button, and then enter all the instructions again.
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
I have a new Sanyo EM-C877B microwave and following instructions in the manual 3.Microwave cooking or any cooking options I will select the Micro Power 1000W then press Start, turn the dial to choose a...
I suggest you revisit the instruction manual and ensure the new microwave is not performing as per instructions.
If that is so you should contact the supplier without delay.
1helpful
How do I enter 50% cook time. time needed to cook, then power button, then what?
It depends on the brand and model, but it's generally:
Time Cook, 2, 0, 0, Power Level, 5, Start or just 2, 0, 0, Power Level, 5, Start.
You can download GE owner's manuals and installation instructions here.
You should be able to download your LG / Goldstar manual here. If not, you can contact them via that page to order one.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
2helpful
4answers
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
8helpful
2answers
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
2answers
Wacked out microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
[email protected]
Sanyo Em-u1000w
i have the same microwave and mine does the same thing,try this push the clock button and enter the time or just push 100 and hit the clock button and then enter in your cook time and hit start.
2answers
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
