Question about Powershot Tool Company Cobra 8000 Forward Action Professional Staple and Nail Gun
Powershot pro staple gun
I have a powershot pro. I do not know how to open it to load staples. HELP!!'
  • 2 more comments
  • carlosmed584 Nov 11, 2008
    cant get staples to feed there is no tension on staples the spring on the staple holder doesnt strech or move? I believe it has too? and the staple does not fit at all something is blocking the sttaple making the path to narrow
  • Anonymous Nov 23, 2008
    Can't get staples to load
    I have a Powershot model 8000 stapler and also can't load the staples. I can pull the track back, but the 0.5" Powershot staples won't fit in the chamber. They are slightly too big. If I jam them in the spring doesn't have enough force to advance the staples forward.
  • Anonymous Dec 06, 2008
    i can't load my stapler gun
Just purchased a Powershot model 5700m. how do you load the staples?
Posted on Feb 23, 2011
You don't put them on the tray, you lay them in the "trough".  The tray comes out from the back.
Posted on Mar 20, 2009
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
No instructions came with the stapler and the . I can't get it open to install staples! I need this now. You start a project and can't get what you need! I was expecting more from a product...
Open the PowerShot staple gun staple chamber. This is found on the front of the staple gun. There is a small metal area on the bottom. Pull down on this and the interior of the staple chamber is revealed.
  • Remove any existing staples that may be in the chamber. These can be pried out with your fingernail, or you can turn the staple gun upside down and gently shake the staples loose.
  • Slide a new row of approved staples into the PowerShot staple gun. These need to be slid in from the base of the staple gun (where you pulled the cover of the chamber off).
  • Close the cover to the PowerShot staple gun's staple chamber and you are ready to use your staple gun on the next household project.
  • May 07, 2011 | Powershot Tool Company Tools & Hardware -...
    How to use brad nails with my powershot pro staple gun
    unload remanning staples and load brads being sure they are in the right side and the head is pointing the right way
    Dec 26, 2010 | Powershot Tool Company Tools & Hardware -...
    I have a Item #9100 Powershot Pro Electric Staple & Nail Gun. I have lost my manual. Please tell me how to load staples.
    I just purchase the powershot 9100 I can't get the trigger to work for the staples to come out. What am i not doing correctly?
    Sep 18, 2010 | Powershot Tool Company Cobra 8000 Forward...
    Cannot find staples for this staple gun. The model I have just says PowerShot on the sides. I purchased some Black & Decker PowerShot heavy duty Staples for the gun but I cannot find anyway to get...
    The ones you have are T-18 I believe
    Fires 6 sizes of T50 type staples and drives 9/16 In. brad nails. Visual refill window and easy load chamber. Comfort grip.
    •Uses Staples: PowerShot Staples, 97-010, 97-011, 97-012, 97-013, 97-014, 97-015, 97-030, 9/16 In.
    •Brad nails
    •Ceiltile 17/32 In., 9/16 In.
    •T50 type staples, 505TML, 506TML, 508TML, 509, 50CT, 506SS, 504M, 505M, 506M, 508M, 509M, 504, 505, 506, 508, 509
    •MFG Brand Name : Arrow Fastener
    •MFG Model # : 5700
    •MFG Part # : 5700
    Aug 13, 2010 | Black & Decker 5700 Powershot Forward...
    Don't know how to load staples in my powershot pro
    Usually a black tab toward the back of the staple gun.
    Push in, pull up and pull out.
    Push rod, spring and assembly should slide out easily.
    You can then reload as needed.
    Push in, pull up and when the push rod bottoms out push down.
    This usually locks the tab back in place. Do this a few times and you will get the feeling pretty quick.
    Oct 18, 2009 | Powershot Tool Company Cobra 8000 Forward...
    When I load the nails, they do not sly to the front of the gun therefore it does not work. Powershot pro 9100 staples/nail gun, eaglalex@aol.com
    Could be couple problems, the magazine, nail carrier is slightly bent or wrong nails is there enough spring pressure on the pusher? and maybe some foreign object in the magazine. Take a look and let me know if you need more assistance
    Sep 11, 2009 | Powershot Tool Company Tools & Hardware -...
    I have never used my Cobra 8000 but need to use it immediately to post signs in my neighborhood re a dog I found. I opened the box, and there were no instructions. I have the gun and some staples. I can't...
    The bottom portion of the stapler (the opposite side of where the staples discharge) should squeeze together and pull out, load staples tip up and reinsert the follower until it clicks.  Put on sign post and squeeze the handle.
    Hope this helps
    Jan 04, 2009 | Powershot Tool Company Cobra 8000 Forward...
    Got it loaded now it won't shoot
    I have a similar staple gun and I figured out I was loading it wrong. If you are loading it where the spring is, like I did, it won't work. there should be another area close to that spring opening that you put the new staples in.
    Oct 02, 2008 | Black & Decker 5700 Powershot Forward...
    Powershot Tool Company Cobra 8000 Forward Action Professional Staple and Nail Gun Logo
    7,636 people viewed this question
    Top Powershot Tool Company Tools & Hardware - Others Experts
    J.D. Browning
    J.D. Browning
    Are you a Powershot Tool Company Tool and Hardware - Other Expert? Answer questions, earn points and help others
