Question about Canon FAXPHONE L80 Laser
Paper jam I have checked and there is no paper jam. Yet is continues to show "clear paper jam."
  • Anonymous Dec 06, 2008
    screen say's check paper jam. I can't find any paper jammed in the machibne.
  • 100 Answers
When this happens it is because the pick up tire has either worn out or has alot of paper lint on it. Remove the toner and I think on this one you can see a rubber wheel in the back middle. You can clean this with a little windex or all purpose cleaner. If it will not pick up the paper after that the tire needs replaced.
Posted on Jan 06, 2009
Printer show paper jam. how do I clear it to continue use printer
Open the printer up and remove any stuck pieces of paper. Check in the paper tray as well by removing the tray and looking inside. Remove any pieces of paper you see then reinstall the paper tray. Your printer should come back up with no jams. If it still says jam then cycle the power to the printer to see if it clears. If it does not clear, you still have a piece of paper stuck somewhere inside. If you can't find ANY paper stuck your printer may need to be cleaned.
Nov 08, 2017 | PRINTER Office Equipment & Supplies
My dell printer shows error after I have cleared the paper jam.
Try and check the ink or maybe the paper is scrunched up smooth them out.. If this doesnt work then sorry this all i can do XD
Apr 04, 2013 | Dell 1250c Color LED Laser-Class Printer...
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
My d7360 printer shows "carriage
Try checking the paper trays, open all the doors and close them.
May 03, 2011 | Computers & Internet
The display says clear original jam but there is no jam
You may need to check again. Even a tiny piece of paper left from when you cleared the jam will cause the printer to continue showing a jam. Make sure to also close any doors firmly.
Mar 08, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I had a paper jam and I took the back off and this
Step one: Remove any loose paper
Remove all loose paper from the input and output trays.
1. Turn off the product.
2. Unplug the power cord from the back of the product.
3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
6. Carefully remove any jammed paper.
7. Close the cover.
8. Reinsert the rear-access panel or the duplexer into the product.
9. Plug the power cord back into the product.
10. Turn on the product.
Step three: Open the top cover and clear the jam
3. Open the carriage access door. The carriage moves to the right side of the product.
4. Gently pull the paper out of the rollers.
5. After clearing the jam, close the carriage door.
6. Plug the power cord back into the product.
7. Try printing a document.
· If the issue is resolved, do not continue troubleshooting.
· If the issue continues, proceed to the next step.
Step four: Clear the jam from paper tray 1
1. Remove all paper from the output tray.
2. Turn off the product.
3. Unplug the power cord from the back of the product.
4. Lift the output tray and then check for jammed paper in input tray 1.
Use these steps to remove any jammed paper.
a. Raise the output tray.
b. Grasp the jammed paper and pull it out of the product, toward you.
c. Lower the output tray.
5. Plug the power cord back into the product.
6. Try printing a document.
· If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
· If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
Step five: Clear the jam from paper tray 2
4. Lift the product off tray 2.
5. Remove the jammed paper from the bottom of the product or from tray 2.
6. Reposition the product on top of tray 2.
7. Plug the power cord back into the product.
8. Try printing a document.
3. Remove the ADF input tray and open the ADF cover.
4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
6. Check the ADF paper path for jammed paper.
7. Check for jammed paper where paper enters the ADF paper cleanout.
o If the paper comes out with gentle pulling, proceed to step 9.
o If the paper does not come out with gentle pulling, follow these instructions.
1. Open the ADF, and then use both hands to gently loosen the paper.
2. When the paper is free, gently pull it out.
3. Close the ADF.
8. Lower the green lever.
Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
9. Replace the ADF input tray.
10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
o Make sure that the ADF frame is secure and attached correctly.
o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
1 - Stack stopper
2 - Two-catch
11. Plug the power cord back into the product.
12. Turn on the product.
13. Try printing a document.
Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
Paper Jam fault
there are sensors that tell the machine the paper is jammed us a q-tip to clean them, remove the toner cartridge and check under that area when cleaning the sensors.
Mar 16, 2009 | Samsung SCX-4521FG All-In-One Laser...
HP Photosmart 2610 - Paper Jam
I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
Continual Paper jam HP Officejet 6310
There's a couple things that can cause recurring paper jams. Most often, all the pieces of the jammed paper aren't removed. This video shows you where to look to find all the jammed paper. It also offers some other solutions as well. If the solutions in this video don't work, the printer is likely broken.
Jul 07, 2008 | HP Officejet 6310 All-In-One InkJet...
Canon FAXPHONE L80 Laser Logo
155 people viewed this question
old marine
old marine
