Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Saeco digital plus not grinding
Not grinding and making espresso. Sounds like it is trying to but no grounds are dispensed and no coffee.
  • 1,089 Answers
Sounds like your grinder is clogged and do you hear a clack, clack? That would be the solenoid opening the doser box.
Posted on May 24, 2009
Coffee pours very slowly
An espresso should take 25 seconds to dispense, long coffee takes longer unless you pour an espresso into 1/2 cup of hot water (or the other way round). It could be the grind is too fine hence extraction is proving difficult. Try making the grinder setting to more coarse. More info in link
Coffee Knowledge
Oct 29, 2012 | Saeco Magic Comfort Plus Espresso Machine
To make coffee stronger do i set the grinder higher or lower
Should set lower it will grind little finer and let espress under pressure absorb more ofbthe flavor, the corrsor it s the faster water flows through grounds, and less flavor.
Jun 11, 2011 | Saeco Royal Digital Plus Coffee...
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Spidem trevi digital plus coffee machine not working as it should
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Jan 27, 2009 | Spidem Trevi Digital Coffee Maker,...
Ground coffee Saeco Royal
Hi
thedalys. you probably have a bad micro switch on your doser. and that just needs to be replaced. If the grinder does not sense that the doser box is full it will keep grinding until it times out.
Guest. Try pulling the dosage lever back one click from the full and push your grind lever to the largest # and see if that helps. Sounds like you grinds are too fine and its clogging the the grind box. If the dosage level is too full it will cycle and dump the brew unit or break the brew drive gears, then you will hear a clicking noise when it trys to make a coffee.
Dec 12, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Won't make coffee
Could you please advise how I obtain a manual for a Saeco Magic deluxe
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
149 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
