Question about Pyle 1800-Watt 2-Channel Bridgeable MOSFET Amplifier Car Audio Amplifier
My pyle amp keeps going into protection when i turn my music up and play it for a min
Everything works fine intil i turn the bass and volume up. when i do it goes into protection. why?
  • adilmahmooda Oct 19, 2008
    i have a 4000w plye amp its working perfect untill i turn the volume up and it goes to protect. the wiring it perfect but i dot know whats causeing this to happen can any1 help me
  • trueblu8 Feb 01, 2009
    God what a dumb answer I just gave. Sorry about that pbabin. You were right, "The most common cause is an unsafe load/speaker impedance". I just realized what caused the problem. I had my speakers wired for 2 ohms. But then by connecting 2 of them in parallel it dropped the load down to 1 ohm. And yeah they got louder but then when I turned up the bass the amp would shut off and go into protection mode because it is not a 1 ohm stable amp. So bottom line is, get out the manuals for your amp and speakers and check what kind of impedences you can run. If that is too overwhelming then consult a car audio expert. Peace.
Yeah right. That's definitely the wrong answer. Those speakers are drawing too much juice for the amp to handle. That's why they don't get really loud until you turn the head unit way up and then the amp turns off 'cause your overloading it. You could try turning your gain down a little bit. Or you may just have to get a bigger amp that can supply the power that those speakers need. Try running just one of the speakers at the same volume. It should work just fine. But then when you hook up 2 it can't handle it. I had the same problem.
Posted on Feb 01, 2009
  • 631 Answers
The most common cause is an unsafe load/speaker impedance. If you have the speakers wired correctly, you may have a short in the wiring. If the wiring is OK, the amp is likely defective
Let me know if you have any other questions.
Posted on Oct 14, 2008
Amp keeps blowing internal fuses on a memphis 16-mcd1000
got pyle pta 3000 watts dj power amp when turn on my power light indcatior light dont work but it still runs
Dec 31, 2013 | Car Audio & Video
I just bought some Performance teknique ICBM 500W and installed them and have a panasonic CQ-RX100U 50w x 4 stereo, its on a 91' ford explorer with a factory amp but not sure if connected. when i higher...
I had a 97 explorer came factory with a JBL system, and had a factory amplifier, I had to get rid of the factory amplifier and by pass it to get my new radio to work... my factory amp was in the very rear passenger under the plastic...... mine worked fine until I installed a new stereo (replaced stock one) and because my stereo didnt contain whatever it was to make the amplifier turn on, had to go bypass the amplifier and I unplugged everything I could find on it. Hope this may provide some clues if any
Nov 01, 2013 | Car Audio & Video
My technics amp SU-G75 keeps shutting off and reads OVERLOAD when played over the volume of -40 to -35. I kept playing around and it works fine when the bass dial is on half, but more bass shuts it off. I...
some amps are made more for low ohm loads (bass) and some are made for high impedence loads (mids/highs) and it seems you are asking too much from your amp.
Mar 05, 2013 | Audio Players & Recorders
Well i was driving one day and my subs just whent out so i bought brand new wires and hooked everything up but the power protector light turns red whenever uu turn it up past volume 10 i really do not know...
It sounds like your amp is going into protection. I know it's frustrating, but this is actually a good thing. If you subs you have are drawing too much power and the amp can't keep up, it will shut off instead of melting the board. Usually, the protection mode only last a few seconds. The user normally turns the music down that the protection shuts off and the music plays again. I recommend looking at a larger amp for your subs, if you are going to play them that hard.
Aug 14, 2011 | Car Audio & Video
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Amp problem
why, why, why, that is the question here.
Sep 30, 2009 | Pyle PLA1200 Car Audio Amplifier
I got a pyle 1800w amp and a 1500w kenwood subs but as i increase the volume in the headunit it goes on protect mode why the other problem i got is as increase the volume in the headunit the bass of the...
The protection modes in these units ****. Most new units have them. What I do is turn down settings on deck and turn up amp as much as possible. Then the protection won't turn on because you won't have to turn it up as high.
Bass goes off when i turn up the volume
You need to install a heavier gauge wire to your amp and a capacitor. It works fine at low volumes because there is enough wattage from the battery to power the bass output of the amp but at higher volumes the amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve of wattage for the amp to use so that it does not run out while blasting your tunes.
Jun 02, 2009 | Fusion FEW12PK Car Subwoofer
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
SPL 1920 watt amp
for 1 never turn the gain all the way up. it is not there to control volume it is there to match gain impedance between other amps and components. 2 i dont know what amp you have so i cant say much about that. 3 test the rca inputs by using a dif set and test the speaker wires as well
Jan 10, 2009 | Car Audio & Video
Pyle 1800-Watt 2-Channel Bridgeable MOSFET Amplifier Car Audio Amplifier Logo
1,050 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
