Question about Coleman Heating & Cooling
To get elec power to my heater my breaker has to be in the off position
  • 124 Answers
The laws of physics dictate that what you are saying is impossible.a unit can not run without power so you have done one of three things. the breaker you are turning off has no relationship to the ac. or the breaker is for the indoor , not the outdoor unit , or you have confused the position of the breaker in the panel with on and off.breakers on the left are on when pushed to the right . breakers to the right are on when pushed to the left. take a volt meter and verify you have power to the outside unit when breaker is in either position. then proceed from have not stated if you have a gas, electric or heat pump heater. but if you have succeeded in generating heat without power we are millionaires, cause it has baffled scientist for thousands of years till now.
Posted on Oct 19, 2008
How to turn it on
There is no on/off switch. With the circuit breaker off you hook up the power lines to it, and then restore power. The thermostat will take care of turning unit on and off as water temps dictate.
Sep 04, 2015 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Insinkerator water heater w152 smoke from power switch
Disconnect(turn off the breaker) the electricity from the unit. There is a short that will cause a fire.
Cause of the short will require investigation
Jul 13, 2014 | Rheem 65 GAL ELEC Water Heater 6YR Self...
How do i cutoff power from hot water heater
typically the power to your water heater would be fed by a circuit breaker in the power panel in your house. water heaters (electric) consume a lot of power and therefor need their own circuit. If your circut box isn't labeled what you need to do is first turn the water heater up so that you can tell that it runing, you can't see this but if you listen closely you should be able to hear it, get someone to help you with this and cut off the power (trip breaker) till you find the one that stops the sound. If you have a volt meter you could take the cover off the power box (where you water heater is hooked in) and put the meter across the black and whiter wire so you see a reading of 110-130 volts. again have someone help you and cut the breakers one by one till the meter drops to 0 volts (or very close to it) when it does, make sure to label the breaker so you know next time.
Mar 23, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I installed a new water heater it has power to it but it is net heating up, is there a reset button if I tripped a breaker within the unit
First a question. Did you fill the water heater until water ran freely at the hot taps.
If not you may have had an air pocket and blown an element. Water heaters will
always be shipped with the ECO in the reset position. The reset is a RED button
located under the upper cover for the thermostat. Shut off breaker to water heater
and remove this cover, and the fiber glass, then push the reset. Replace the fiberglas
and the cover securely and turn on power. You should actually hear the heater in most
cases. Remember that it takes about 45 minutes for a full tank of hot water from startup.
Feb 27, 2011 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Brand new no hot water
Turn off the power check all your connections. Check for a tripped breaker. If can use a volt meter check for power and check continuity of your elements.
Oct 07, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My water is not hot and discovered the panel breaker tripped. the panel breaker keeps tripping for the water heater and will not reset either.
Problem could be a shorted element. Disconnect the wires from the breaker and try to reset it, remember to flip the switch in the fully off position before moving it to the on position. If the breaker doesn't trip then the problem is in the heater itself. If you have access to an Ohmmeter, with the power turned off check the continuity of the elements across the screw terminals and from the terminals to ground. There should not be a reading to ground and a high resistance across the terminal screws
Aug 25, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
There is no hot water
Hello Check the curcit breaker in the house electrical box.It should MATCH the position of all the others(ON)
Aug 13, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The black wire in the hot water heater is glowing red, I can hear a noise in the breaker bos so I pulled the breaker loos and the plastic to the panel has been melted.
Breaker may be defective and not clipping off when it overheats. More and more power keeps going through it and nothing to stop it. Or check the wiring on the heater itself to be sure they are connected right.
Jan 27, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Breaker is tripping off every 20 min i know amp are right plz adviced me how to fix
need to know which breaker- house ele. panel breaker, which should be a min. of 50 amps,or the element breaker located inside either the upper or lower cover. If it is the element breaker/reset switch, this can be changed with great ease. Turn the power off and the ele. panel, check with a voltage meter to make certain power is off at the unit, loosen or remove the wires- making sure as to location of wiring, remove the switch and replace, reconnect wires, turn breaker back on,and you should be ready to go, This is assuming you have a 50 amp breaker in the electricial panel.
Nov 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Elec. water heater
Have you turned breakers back on?? Please rate. Thank you. jj505
Mar 25, 2009 | Water Heaters
Heating & Cooling Logo
44 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
