I have a whirlpool duet front loading washer model wfw9200sq00 that will not start. It gave an error code of f71 and would not start a cycle. I unplugged it and replugged it in and now nothing works. There is no digital display The machine is about 1 year old.
  • 3 more comments
  • Anonymous Nov 23, 2008
    I have the same problem with error code F71. I had a technician come out and tell me I had to replace the CCU and the door locking mechanism. He gave me a quote of closet to $600 for parts etc. - That's disgusting!
  • sabers75 Apr 19, 2009
    we have a whirlpool duet model WFW9200 SQ00 washer that although the different water temp lights are lit, it won't allow you to change from (for example) warm water to cold on any cycle. ALso the light around the cycle selector button lights up, flashes and it beeps. The only way to stop the beeping throughout the entire cycle is to lock the controls. is this a problem with the main circuit board?
  • Woody Lansford Apr 24, 2009
    Duet wont start. Used the guide under washer to start diagnostics which showed code of C:00 so replaced door lock assembly, but still wont start.
  • BNemeth May 06, 2009
    When these guys say the "CCU" needs to be replaced. What part are they actually referring to? The microcomputer, or part of the user interfaces?
  • xianshi May 08, 2009
    replaced control board, still does not work.  door is not locking now either.
  • 3 Answers
That display code is associated with the control panel failing. You will probably need a technician to come take a look.
Posted on Oct 13, 2008
We are having the same problem w/ a whirlpool front loader. it has been ongoing for 2 years. at this point we are trying to get the entire machine replaced. the error code stands for loose wire.
Posted on Oct 30, 2009
How do I know which user interface I need for an error code F71? I'm getting an F71 error code. The washer will not start at all. Model WFW9200SQ00 Whirlpool
Hi
F71 is a communication error and is displayed when there is no communication from the User Interface to the Central Control Unit. First check the user interface harness for continuity and then check the wire harness to the user interface and CCU. If the drum rotates then replace the user interface, if the drum is not moving then replace the central control unit (CCU). Hope this helps...please post back for further assistance.
Daniel
Aug 11, 2011 | Whirlpool Washing Machines
We have a duet washer wfw9200sq00 and it won't power on - just gives 3 beeps. I did get a F71 error code
F-71 user interface heartbeat failure, com failure between touch pad and central control.
You ain't sitting goopy liquid detergent on top of the washer is ya? Stuff goes down into the controls and oopzy. themobilian_2505.jpg
Service manual for duet with repair photos
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code f 71
Check to see whether the laundry drum to the washer moves. If it does move, then the user interface needs replacing. If the drum is locked and will not move, you need to replace the central control unit on the washer.
Read more: Whirlpool Duet Error Code F71 ' eHow.com http://www.ehow.com/facts_7618431_whirlpool-duet-error-code-f71.html#ixzz1AANUprMm
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F71 mean ? This comes up half way through the cycle
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Oct 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet washer model number WFW9200SQ00, serial number CSU0706727 is showing code 71 can't find that code anywhere. Before I unplugged the washer the lights where all working but it would not...
You have a user interface heartbeat problem. The front control panelis malfunctioning due to either not being plugged in correctly, or it's faulty, orthe central control unit is faulty!
Sep 06, 2010 | Whirlpool Washing Machines
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F71 f71 error code comes up. What does it mean? I'm not sure when it happens during cycle.
It seems the only solution any one has is to pull the plug. If this doesn't solve problem replace board. Seems to me if so many people have this same problem with fairly new washers its a design flaw and should be addressed by whirlpool. $600 for a new board seems outrageous for a new washer.
Jan 19, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
1,009 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
