Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 will not power up
The power supply and hard drive check out as OK.
The light on the motherboard is green, so power gets that far.
But when you press the power button, we get nothing. Not boot up, no beep codes. nothing.
Is there a way to test the motherboard and the power button
  • Anonymous Oct 30, 2008
    I have the same problem. I took everything out and cleaned it, put everything back in except the front panel, which I connencted to the sound card and motherboard. I booted right up.
    But after I shut down and put the front panel back in -- nothing.
    You can force power to the motherboard by shorting out the green with any black on the 24-pin connector. This turns on the power supply. When I do this, my hardrive spins up, my drives work, my CPU fan works, everything works except the motherboard.
    Still won't boot with Modem and Sound Card and RAM removed. So, I probably have a bad MB, SPU or Video Card
No doubt you've fixed this or given up by now but in the interest of helping others with this problem here is a solution. I had the same problem and it turned out to be the Front I/O & Control Panel Assembly. I suspect that the USB ports had shorted out and took the whole card down. The not turning on problem was preceded by the USB ports failing. I couldn't figure out how to bypass the card to power the computer. Dell won't help if you are not under warranty (unless you purchase some additional support). I couldn't find a replacement board on Dell's web site but found some other vendors that sold them. I bought one for about $70 and it did the trick. There seems to be at least two similar model numbers for this card. I don't know if they are interchangeable or what the differences are. If you look on the card there should be a series of numbers. Look for an "X" followed by 4 numbers. In my case it was "X8682". This is the model number for the card. If you search for shopping sites with your Dell model and this card number you should find vendors to buy the card. I think this is a design flaw having the USB ports on the same connection as the on switch. It looks like many people have had this problem. One bad usb port and your whole system is taken down. My guess is that the average user is not going to be able to figure this out and will spend lots of money unnecessarily. For those comfortable opening up the case and covers (you can download the manual from the Dell site) and unplugging ribbon cables this is a fairly simple fix. Keep in mind the card won't come with any instructions. Make sure you follow power safety rules and ground yourself.
Posted on Jan 12, 2010
I HAD THE SAME PROBLEM WITH MINE.. I CALLED DELL AND THE GUY TOLD ME TO DISCONNECT EVERYTHING FROM THE BACK OF THE COMPUTER INCLUDING THE AC POWER AND PRESS THE POWER BUTTON FOR 15 SEC.. I PLUGGED EVERYTHING BACK AND IT STARTED UP..THE PROBLEM HE TOLD ME WAS OVER TIME THE COMPUTER BUILDS UP STATIC SO BY PRESSING THE POWER BUTTON WHILE EVERYTHING UNPLUGGED DRAINS OUT THE STATIC..IT WORKED FOR ME AND I HOPE IT WORKS FOR YOU....
Posted on Oct 26, 2008
Yo have a dead system board my friend i just ordered a refurbished one and have a new problem
Posted on Oct 17, 2008
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 - usb ports on motherboard are broken
Flashing Amber is normally power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The USB ports are part of the motherboard
Jun 08, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dimension 5100 will not turn on
Could be a bad motherboard? If your power supply was really fried it could have also fried your motherboard.
Mar 25, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Computer will not turn on at all. Dell Dimension 5100 desktop
I would unplug the power supply from the motherboard, wait a little while and then plug it back in.
Try to power everything back up and it should come up.
I am assuming you are getting a light on the motherboard that indicates power is being supplied?
Feb 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100, Doesn't Boot Up, Display Lights Up "!, 2 3"
2 green lights usually indicate a memory problem, however, when you get 3 lights, RAM is good, but the BIOS is unable to hand off to the operating system.
To test this, disconnect your hard drive (both ribbon and power) and connect the monitor. See if you get a display. If you get a display, try carefully reseating the cables to the hard drive and also to the motherboard.
If you lose the display again, disconnect the hard drive and connect your DVD/CD and put in a Windows or diagnostic CD to see if it will boot.
If it does, you have a bad hard drive.
Let me know if this helps or you have other questions.
Honest1abe
Jan 27, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Slave drive into Dell Dimension 5100
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Jun 07, 2008 | Dell Dimension 4600 PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
1,737 people viewed this question
Alun Cox
