Question about GPS
Garmin 205 running watch/ need to set actual time
The watch has multiple screens but I can not figure out how to set the daily time
  • steve hicks Oct 13, 2008
    Wrong device - this is a watch - Garmin forerunner 205
  • steve hicks Oct 14, 2008
    I have the manual but cannot figure it out
  • 928 Answers
It was only now that i saw your original post
One option is to touch the time settings in the top right. You can then change the time. Another option is below.
To update the time.
Go to Tools> Settings>Time
Time Format select either 12 or 24 hour time format
Current Time - you can manually set it or automatic to have the nuvi set the time based on your location.
The link to the manual is below as well.
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
http://www8.garmin.com/manuals/2459_QuickStartManual.pdf
Posted on Oct 13, 2008
Garmin 205 and heart rate monitor
What is the problem?
If you are looking for a heart rate monitor, one can be found here.
http://www.gpscity.com/garmin-heart-rate-monitor-with-soft-strap.html
Jan 05, 2012 | Garmin Forerunner 205 Gps Training Watch
Tip
How to Perform a Hard Reset of your Garmin Nuvi 205 and 205W
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
_______________________________________
Download Garmin Nuvi 205 Manuals here.
Garmin Nuvi 205 Favorites Backup here.
Garmin Nuvi 205 WebUpdater here.
on Jan 15, 2010 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 205 - when I switch it on the maps load up and after the warning screen a screen appears with the message "Stay up to date with your Garmon Safety Camera Data at my.garmin.com" I try...
You probably need to update the unit at their website. In the meantime, you can try the reset button There is one, but it's kind of stealth - it's on the angled edge of the bottom of the device, in a square "hole". Pressing the corner of the screen resets user data only, not the actual device. Good luck!
Apr 29, 2011 | Garmin nuvi 205 GPS Receiver
I have had my garmin forerunner 205 since end of May 2010. It recently started taking longer than normal to find satelites. On my last run it came up as saying battery low when I had only just charged and...
You need to contact Garmin and have them replace or repair the watch. If the watch is less than a year old, it will be under warranty. Older than a year it may be a repair or replace only situation, Garmin will have to determine that. It is not unusual for the forerunner series to have rechargeable batteries that die off.
Jan 04, 2011 | Garmin Forerunner 205 Gps Training Watch
Does garmin 205 have a light up screen for night use?
Yes it does. Pressbutton 1 (top left hand button) to turn on the light and again to turn it off.
If you don't have a copy of the user manual, go to http://static.garmincdn.com/pumac/984_OwnersManual.pdf to down load a copy.
Dec 12, 2010 | Garmin Forerunner 205 Gps Training Watch
My Garmin Nuvi 205 touch screen will not work. I've calibrated multiple times but the screen is still not interactive
It sounds like your screen has died on the unit and will need to be sent in for warranty, if it past the unit 1 year manufacturers warranty it is usually cheaper to get a new more up to date unit.
Hope this helps!
Dec 08, 2010 | Garmin nuvi 205 GPS Receiver
Uploading multiple days of runs to Garmin Training Center
Yes it will hold ALL you runs AND keep them seperate. What you need to do at the end of each run just before you turn it off hit and "hold" the Lap button (reset button). It takes a second but you should see it say reset in 3-2-1. Keep holding untill the process is finished. What this does is end your run and saves it in the watch. When you start your watch the next time it will start a new run when you hit start. By doing this it will keep everything sorted when you down load. In the software you will see one enty with a + sign beside it. The first entry you see is the total of the week. If you hit the + you will see each individual run.
Hope this helps.
Mar 18, 2010 | Garmin Forerunner 305 GPS Receiver
Can't get Garmin Nuvi 750 to turn on
I had this problem and tried to return it 3 times but the store always got it on. I finally figured out that on the bottom of the Garmin is a reset "button." There is no actual button, but you will see where it says "reset" Push that. See http://www8.garmin.com/manuals/2458_QuickStartManual.pdf for the Nuvi 205.
Jan 18, 2009 | Garmin nuvi 750 GPS Receiver
GPS Logo
344 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
