Question about Canon Office Equipment & Supplies
Pixma 780 prints red and yellow bars instead of color image
  • 4 more comments
  • askwerski Oct 13, 2008
    Prints red and yellow horizontal baras instead of color image. All cartriges have ink. Ink supply does not appear to be problem.
    images appear but are broken up woth the 1/4 in red and yellow horizontal bars. Looks like you are looking into a room with venetian blinds or a perpermintd stick.
    New problem. I I get the message "Put in cartrige" on printer. Messageon computer screen says , "Install print head". Now nothing works.
    First how do I remove the cartrige head and even greater problem. Now the printer has shutd itself off and will not go back on. I cannot turn the printer on. Have checked all plugs wich are secure.
    Before I can do anything I have to get the printer to turn on. Is it possible that I "blew" a fuse or tripped a circit breaker. Until I get the printer up , othing can be done. ANy tips or hints...or is Mr. Pixma gone.
    Got any suggestions for service locations. My zip code is 60302. Oak Park, Il
    Genius:
  • 1,226 Answers
did you verify the cable connecting from the printer head to the printer circuit board? if not then you have to verify it for checking. actually like that problem is due to error in the circuit board and need general cleaning in all parts of it. to eliminate mold in the circuit, accumulated dirts and other annoyance to your printer.
all parts are plug in however it needs semi technical person.
melnavz
Posted on Oct 13, 2008
    President:
  • 2,712 Answers
This is most likely because of using generic or refilled cartridges. Most printers these days have a sensor to detect refilled / non-original cartridges, which can cause printer problems in the long run. This is to encourage consumers to buy only original inks.
As for the printer not turning on, try a different wall socket first. If possible, try to change the power cable as well. You could also try a hard reset - Unplug printer from wall socket and PC, wait about a minute and try again.
Should none of these steps work, then I'm afraid you will have to take the printer in for servicing. Although if you ask me, I recommend going in for a brand new printer, as service charges will be nearly as much (if not more) than the price of a new printer...
Cheers!
IrishDruid
  • Canon Master
  • 1,879 Answers
Problem got worse
disconnect the printer from the computer and power source
look for another power outlet and try powering on the printer, if that doesn't work, you got to accept it needs servicing.
  • Canon Master
  • 19,396 Answers
The printer shuts itself off because is defective. And it was defective even before you performed the ordinary maintainance operations suggested.
The printer has a faulty printhead, that was the reason for the color bands.
It is also apossible a fault with the main control board.
Repair service should be performed by a technician.
  • Ginko
    Ginko Oct 13, 2008
    If you blew a fuse or tripped a circuit breaker, the printer would not even start. If you blew a capacitor, or an IC on main circut board, yes, that can cause the problem.
    The only way to test this is going through a several hours testing job done by a technician on the main board, usually to find out that the print head is gone and must be replaced.
    No professional repairer is doing that kind of job on an inkjet printer, it is not worth nowadays.
    Sergeant:
    Champion:
  • 281 Answers
You need to go to the option and disable these unknown colors.
Hope this is helpful
    Scholar:
  • 136 Answers
Remove all the external wiring connections connected to the printer such as usb wire.
then remove the cartridges
then OFFthe printer.
then unplug the power cord of your printer from main power out let.
wait for 5 minutes.
then plug the printer wire in the power outlet.
ON the printer.insert the cartridges.
then connect the usb wire*(the communication wire between computer and printer)
then check it will work.
thanks.
  • ready2helpu Oct 13, 2008
    your printer needs a reparing at a service center.it is worth reparing the printer.
    as this is a minute problem of reset in your printer and it will be repaired.
    thanks.
    Master:
  • 538 Answers
First thing..can you run a test page..and report those results..
  • A Womans Computer Man
    A Womans Computer Man Oct 13, 2008
    ok..that is from the print engine side..did you install new drivers recently..that may correct this..
    Sergeant:
    Champion:
  • 435 Answers
Hi, Sould like problem with catridge. Check if none of the colors in the catridge are empty.
  • Karthik P Oct 13, 2008
    I believe there should be a software which comes with printer to tell you about the ink levels in the catridge.
    Ok.
    Try doing the printer head clean using the software.
    May be some dry inks are stuck on the head.
    Top Expert:
  • Canon Master
  • 79,123 Answers
Soak just the cartriage print head in warm water for a few minutes, this may cure the problem if it is ink flow related as it sounds it might be.
How to make red color work in canon pixma mp287
make sure that there is red in the cartridge to use
Jan 07, 2017 | Canon Office Equipment & Supplies
MY CANNON PRINTER IP3600 IS PRINTING RED IMAGES IN PINK
go to Edit > Color Settings, how is Photoshop Elements currently set? The first thing I would do is try setting it to "No color management" and see if you get better results. If this works for you, you're in luck, because color management gets tricky.In settings "No color management" does not produce acceptable results, you will have to start reading up on color management and color calibrating your devices, particularly your printer. You might want to also read Photoshop Elements Help topic "To print using color management."Most graphics software has setting for color management, but personally, I have always gotten the best results by simply turning color management off. Color management is primarily intended for people in a pre-press environment. Not everyone needs it. If you're not doing professional printing, first try working without color management before you assume you need it.
Apr 26, 2012 | Canon Pixma iP3600 InkJet Photo Printer
Output of color red image is color yellow
The Magenta color cartridge is either empty or the print head is blocked.
Oct 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Pixma ip4000 prints blue instead of green
The fault could be -
The yellow cartridge is empty
or
The yellow ink nozzles are blocked
Because green is made up with blue and yellow colors.
Sep 12, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
This Canon MP530 will print a nozzle check with no problems. It will color copy with no problem. No ink cartridge lights are on. It will not print a report or copy in black. What's wrong?
On your nozzle check, do you see the grid at the top (indicated by red arrow in picture below)? If you don't see this, your pigment black nozzles aren't working. The black bar at the bottom is from the dye black nozzles (small black tank). You may have either plugged nozzles or a bad print head.
Mar 02, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon irC3200 Yellow Bar Going Through Prints
try this press asterisk* with head then on the control panel press adjustment and cleaning then go to clean main inside unit run this 2x. try to phocopy white paper only .check wether the yellow bar is still there it could be this a problem of transfer belt cleaning unit .you can clean this by removing the waste bottle and remove one screw and pull out the cleaning unit and cleaned it and return everything hope this will help
Jul 12, 2009 | Canon Office Equipment & Supplies
Cannon Pixma MP 780
your MCY (color) cartridge is damaged, or either needs cleaning, try to remove this and clean the head with a soft cloth and re-install once again, if it doest work then replace the cartridge
Dec 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printing error (Canon ip1800)
replaced ink cartridges..error message appears now telling me to re align printer..can you tell me how to do this
Jul 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Colors print different
Is it because the ink has run out of the cartridge, replace all the cart
Jan 17, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Color is off...too much red
Your color profile is off
Click on start / printer and faxes
right click on your printer and select properties
click on the color management tabe and selct another color profile
If that dont work
in the printing preferences (propteries) adjust the amout of maganta(red) down a bit to compensate for the rest..
but the problem is your color profile
Nov 28, 2007 | Canon PIXMA MP780 All-In-One InkJet...
24 people viewed this question
old marine
old marine
