Question about Brother HL 5170DN Laser Printer
Easy peel Labels stuck to rollers cant print
When printing labels with easy peel labels two labels stuck in the rollers how do I retrieve the lables
    Problem Solver:
  • 14 Answers
On which roller are these labels stuck? On the drum roller? or at the back in the fuser.
If it is the drum you can always try with a soft cloth and some denatured alcohol.
Soak the label first with alcohol to loosen the glue, then remove the label and take a new
clean cloth to remove the glue with alcohol. Notice that the drum is light sensitive, don't expose it to bright light for too long.
If it is in the fuser you'll have a bigger problem. You'll have to remove the fuser first to access the rollers (caution, let it cool down first, fusers get really hot)
You need to remove the duplex unit (if available) or duplex cover and the 2 small side covers.
In the left and right you will notice 2 screws that tighten the fuser. Remove these screws as well as the dataconnector on the right and the fuser lamp power supply to the left.
Now you can easily slide the fuser out.
The tricky part is to open the fuser up to access both heat- and pressure-roller to clean them in the same way you should clean the drum unit. Normally you can open the top cap of the fuser loosening 2 screws don't know exactly which ones
When this is done you can reassemble the printer and all should work fine.
If you intend to open up the fuser, let me know, i'll get you the detailed information for that.
Notice:
when you use lables that are suitable for laserprinters always use the manual front feed and open the rear cover, that way the paper does not get folded, it just runs flat right through the printer.
Posted on Dec 06, 2008
I cannot retrieve FABRIC from inside machine. I was printing labels and now one is rolled around the roller inside.
About 1,350,000 results (0.86 seconds) Search Results
    [PDF]How To remove a stuck label from the LabelWriter? 1. the ...
    global.dymo.com/.../cRydqiFncuah2s6Pf5DxrozTFs...
    DYMO Corporation1. the labelwriter. 2. ... The cover is now completely removed. 7. lift up the innerguidance ... Make sure the rubber transport roller ... under the stuck labels with the cutter ... the front is completely in place. 31. Your LabelWriter is now ready to print.
    [PDF]Instructions & Troubleshooting - Pelikan Artline
    www.pelikanartline.co.nz/images/.../5InstructionsTroubleshooting.pdf
    Page 1 ... E Labels. F Platen Release Knob. G Ink Roller Loading Catch. H PrintHead. I String. Lift off the ... Determine whether the label roll is the ... on the roller inside the label ... Label Loading is now complete ... Index Bands all around.
    [PDF]Label Path Diagram - Primera
Jan 18, 2016 | Office Equipment & Supplies
Tip
Keep labels from coming off
It seems like its inevitable, you print your own labels at home and then a few months or even weeks later those labels are starting to peel off. With one small tip you can keep those labels from coming off. What I have been doing with the labels that I put on my kids school supplies is rounding off the corners. After I print the label and trim it down to size I just trim off the corners to make them round and it works wonders. This works simply because when you have a sharp corner it is easy for stuff to get in under the label and then before you know it the whole thing is coming off. By rounding the edges you make it harder for stuff to get under it.
on Sep 15, 2013 | Office Equipment & Supplies
How can i print?
Go to the Argox web site does your model printer do labels? check the media spec's. Are using the correct setting in the print driver? Check the printer setting on the machine. web site mite have a work around also might go to web site down load up grade driver to allow ding lables
Oct 16, 2015 | Argox OS-214 Label Printer
Cant print labels
printing from the wrong tray or the lables are not in the right tray
Jan 22, 2014 | Konica Minolta Office Equipment & Supplies
I printed up lables and one of my labels stuck to
Turn it on, allow it to home, mark the printwheel with some white out.
Turn it off and on a few times if the mark dosen't always return to the same place the homing pawl is broken, you need a tech.
DickyO
Jun 04, 2010 | Brother Office Equipment & Supplies
Something stuck in print cartridge
if the label came off on the drum then no, the drum is the blue or green roller that is protected by the plastic flap. A quick easy way to tell is that there should be 3 or 4 marks on the page, evenly spaced, this will indicate something stuck on the drum. The only repair is to replace it, because of the highly sensitive material that it is made of.
Apr 02, 2009 | HP LaserJet 4600dn Color Printer
How to feed labels on zebra s4m
The issue that is causing the problem is when users tear off the label they are actually partially pulling on the next label causing it to peel away a little then when it feeds it will jam. Only reliable way to stop this is once the user prints tell them to press feed and feed 1 label through.
Mar 31, 2009 | Zebra S4M Thermal Label Printer
Anoterh Vertical Line Problem!
So many questions Vertical lines suggest [you do mean vertical do you - up/and down?] is new one to me try www.fixyourownprinter.com Printing CD's is not a 2200 thing, it is the province of the R series. Printing lables is easy purchase CD labels and suitable CD print software - A kit including labels software and label applicator is available at many computer stores Other labels- download the Avery-Dennison free lable software.
Aug 01, 2007 | Epson Stylus 2200 InkJet Photo Printer
Brother HL 5170DN Laser Printer Logo
346 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
