Asko washing machine w6342 showing f3 and cant open door or operate?
I cannot open the door to my washing machine, i have pulled plug and then reconnected and it does not open. It sounds like it is trying to open the door but cant. There is a load in there and its never happened before?
I suggest call ASKO on 1300 00 2756 and ask for the service dept. It could be something very minor like a blockage in the drain pump.
But it better to have someone look at this.
Posted on Oct 14, 2008
  • 417 Answers
Make sure the programme selector switch is at an end of wash position as these door locks are interlocked to prevent accidental opening during operation. There is also a 2-3 minute time delay after the was finishes so disconnect for say 5 minutes and try again.
If it still doesn't open you will need to get access to the mechanism dependent on what type of relrase mechanism you have;
if it is a push button release with a cable to the lock sometimes you can remove the top panel of the machine and pull on the cable or linkage to open.
If it is a lever type release mechanism this is more difficult to open but you can sometimes reach and release it by the same method.
Always disconnect the machine from the electricity supply before working on it.
Posted on Oct 13, 2008
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
Reset asko w6342
you do you know that you have to wait up to 3 min for some doors to open as there is a safety lock on them other than that check your door lock
Jan 27, 2014 | Washing Machines
During the washing circle the machine stops and F3 appears in the time window and machine cant restart
If F3 is flashing, then you are having a problem with drainage.
Check that there is no object stuck in the drain hose outlet. Check that the pump is not blocked by foreign objects and clean the pump. Check that there are no kinks in the drain hose.
After making these corrections, run the drain program or press the key button (door open) to empty the machine.
Feb 10, 2011 | Asko W6222 Top Load Washer
W6342 displays F3 on the front panel, what do I do?
F3 is a drain problem, check that the drain hose on the back is not kinked, if not then you may have a restriction in the drain pump. Follow these instructions:
The washing machine has a trap, where
coins, hairpins and the like can get caught.
To clean the filter and drainage pump:
1. Make sure the machine is empty of water
and that it is switched off or better still unplugged,
2: Open the hatch on lower front of machine for the drainage pump,
3: Drain out the water, into a bowl, for
example, by unhooking the drainage hose
from the pin inside the hatch. You may have to remove plug in the end of hose, be careful, as water should flow real good from hose, if water does not flow from hose and you see water inside of tub area with door closed then stop here and call a tech for repair, if water flows then allow water to fully drain out, then
4: Unscrew the cover anti-clockwise and
remove. You should then be able to see what is inside trap. More than likely you washed a rug and it came apart and blocked drain pump.
5: re-install in the reverse order and then try machine. In some cases you have to do this two or three times in a row to get it all out.
Oct 17, 2009 | Asko W6021 Front Load Washer
Washing machine wont drain, door is locked, and cant get clothes out of machine, says F1 and F3 error. wat do i do?
sounds like a safety check is on. check the pump to make sure nothing is stuck in there. read the manual for checking pump on that Asko machine..
Oct 14, 2009 | Asko W6021 Front Load Washer
I have an asko wm200 washing machine. I have an F3 error, which is stopping me from opening the washer. The washer is also still full of water. Just need to know how to get the door to open and the water...
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Jul 08, 2009 | Asko W6761 Front Load Washer
Not only is my asko washing machine leaking, the code "F3" flashes continuously, and my clothes are locked inside. What does "F3" mean? and how do I get the door to unlock?
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Jun 30, 2009 | Asko W6441 Front Load Washer
My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jurgo
Jun 15, 2009 | Asko W6461 Front Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
Washing Machines Logo
557 people viewed this question
Top Washing Machines Experts
