Question about Zenith Z32X31D 32" TV
PIP change I just bought a used Zenith with PIP. I know the PIP works because it was tested at the store.......I can get the small box on the screen but it is showing the same channel as the main screen? HELP
    Champion:
  • 252 Answers
You can change the channel of the small screen .just read the user manual of your tv.to your problem is only in the remote control
Posted on Oct 15, 2008
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
Zenith PV4663RK Rear Projection TV - Manufactured - Mar. 1995
Are you connected to cable TV using a digital receiver? If so, your TV can only get the signal for one channel - the one you're tuned into on your receiver. A workaround is to connect the coax cable TV cable directly to your TV, as well as connecting your receiver to your TV. This will allow you to be able to change the channel on your receiver and be able to change the channel on your TV to one of the analog channels you can tune into by connecting the coax cable directly to the TV.
Jan 09, 2008 | Zenith IQB50M90W 50" Rear Projection...
TV DOES NOT RECEIVE THE SIGNAL FROM REMOTE CONTROL
radio shack used to sell the box dont know for sure if they still do
Feb 05, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
I want to know how to use some features on my Zenith MBR3447 remote
My guess is SURF might let you scan through the channels like a scan button on a car radio. PIP stands for picture in picture and may require a second device(vcr etc.) with a seperate tuner to use. SWAP allows you to swap pictures when useing PIP. Freeze probably will allow you to freeze the current picture on the screen.
May 14, 2008 | Zenith MBR3447 Remote Control
Pip for my iQB36B44w
The PIP may only work with an external tuner or source (VCR, DVD, CATV box, etc) If your TV doesnt say "dual tuner" then you need an external source for the PIP (Use a VCR and its tuner for instance)
Feb 13, 2008 | Zenith B27A11Z 27" TV
Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Jul 25, 2007 | Zenith Z36X31D TV
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
