Question about Vivitar 283 Flash
Batteries Can I use my nMh (nickle metal hydroxy) batteries in my Vivitar 283 flash? In the past I've used regular AA batteries--and I could just go by some--but I have the nMh available. Thanks.
  • 4 Answers
I use Duracell 2650 mAh rechargeable AA's with my 283 all the time. You may read that 1.2v Duracells or other rechargeables will not work because of the slightly lower voltage (alkalines are 1.5v).
I believe the problem lies not with the voltage, but is due to the slightly fatter profile of the rechargeables that causes a tight fit in the Vivitar battery pack. I find that, after inserting all four (the last will go in really tight), I need to give each cell one more firm push so that it seats properly into the battery pack.
Good luck.
Caruso
Posted on Jan 03, 2009
Do i need the battery adapter for my vivitar 283
The 283 and 285 require an adapter to hold the 4 AA batteries. This is because there is an available battery pack NC-3 (NiCad) that works with the Charge-15 rapid charger. Loose AA batteries cannot be used without the adapter known as AP-1. They are all over eBay and quite reasonably priced.
Jan 31, 2014 | Vivitar 283 Flash
Where can I purchase a new or used battery holder for a Vivitar 283 flash attachment? Mine was left in too long and the batteries destroyed the contacts.
Best place for finding Vivitar 283 anything is on e-Bay, I use a gang of them doing my location photography and have several holders preloaded with batteries so when the cycle time starts to get more then I can bare I just switch out the holders.
All my stuff came off e-Bay.
Feb 21, 2011 | Vivitar 283 Flash
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
My vivitar 283 flash won't turn on. I checked the
Check the contacts for the battery to make sure they are clean and shiny. Then insert 4 brand new AA batteries observing the correct polarity and try again. Also check your users manual to be sure all of your setting and connection to your camera is correct.
I hope this was a help to you and good luck!
Nov 13, 2009 | Vivitar 283 Flash
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
Battery holder for Vivitar 283 is broken. Can I get a replacement
I think there are some listed on Ebay-check it out.
Dec 27, 2008 | Vivitar 283 Flash
Vivitar 285HV Stop Working
There is nothing wrong with your flash unit. The regular AA batters are 1.5 v volts each- if 4 batteries are used that is a total of 6 volts for proper operation. The rechargeable batteries are 1.2 volts each and 4 will get you 4.8 volts- thats 1.2 volts short and that is probably the root of our problem .
Try recharging you rechargeable batteries and put the im one more time- if the same problem happens you will have to stick with standard AA batteries. There external 6 volt packs that will work with your flash unit0 the are a bit of an expense at first but you will save on replacement batteries in the long run,.
Ed
Nov 27, 2008 | Vivitar 285HV Flash
Vivitar 283 flash will not work on camera.
To test everything except the camera, just short the contacts on the Wein protector. If the flash fires, the problem is in your camera, and maybe the protector did not do its job as good as expected.
Good luck
Aug 29, 2007 | Cameras
Vivitar 283 Flash Logo
100 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
