Cars & Trucks Logo
Posted on Oct 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Iveco servicing please help ! can anybody tell me when the axle oil needs changing on my iveco daily 35s12 the van has done 85,000 miles its 3 years old. thanks
  • 2 more comments
  • Anonymous Mar 12, 2014
    iveco daily fusebox layout
    need fuse box layout for iveco daily 03 model
  • Anonymous Mar 13, 2014
    iveco daily
  • Anonymous Mar 17, 2014
    iveco daily horn not working
Anonymous
Level 2:
Sergeant:
  • Expert 350 Answers
  • Posted on Oct 13, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
350
Questions
0
Helped
152846
Points
757
Hi the axle is one of the few things that don,t fall apart on these vans but gearbox oils axless etc like engine oils need replacing regular if you want them to last i would change it every 50000 mile yates210456
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1524
Points
How to remove thermostat housing on model or type 8031105.05 3cylinder iveco diesel
Anybody how do you start an Iveco daily van when you have lost the key code
There's no easy way to by pass the immobiliser get it recoded.
1helpful
How do I get my 07 Iveco daily to start as I changed all the fuses as I had blown the wiper one and now the immobiliser does not let me start it.
Try starting from scratch, disconnect battery for a few minutes and reconnect, ECU are usually reset and it may clear this default in your immobilizer. FREE-PPV.com
HOW DO YOU RESET THE OIL SERVICE LIGHT ON AN IVECO DAILY
No simple way. Has to be done at dealership.
My chrysler 2002 300 m special 85,000 miles, replaced transmission at 55,000 miles, all of a sudden it is hard to put into park, transmission fluid is fine, checked last week when had oil changed. any...
Had the same problem a few years back. It may be a gear shift cable. I had to replace mine. The job is about $450, the part and about 3 hrs labour
2answers
Please advise me proper maintenance for 2007 jeep liberty sport 36000 mile. last service (34000) it was a list of supposed required stuff to do. just want to know what is needed and not. thanks
I don't know how much maintenace you have done in the past. Besides the normal inspections of the brakes, fluid levels and oil changes they do recomend changing the spark plugs and the axle fluid at 30,000 miles and adjusting your parking brake cable. hope this helps....
2answers
What service is done at 90kon a 1999 caravan - apparently my mechanic doesn't dooil and filter change -- or tuneup as part of service
you have a cooling system flush and transmission change not flush an filter change the best thing i can tell you is to stop by your local Dodge dealership in the service departmnet and the manger or one of the servicewriters will give you a sheet telling you what service you will need on your van you can also give these websites a try www.alldatadiy.com and www.autozone.com wish you the best of luck Michigan Man.
1helpful
3answers
Service won't reset
if you look carefully in the owners manual it will tell you how to reset it
3helpful
3answers
Transmission service
You say you don't tow anything and you only got 85,000 mi. on the truck i don't think it is neceassery. Just chg.filter and oil and blow out the cooling lines and you should be good to go. I'am not saying its a bad or an expensive procedure i just don't think its neceassery.
7helpful
2answers
Reprogramming blank key iveco daily
Unfortunately there is no solution to this except to take it back to Iveco for reprogramming.
I am led to believe from my locksmith that there are two types of transponders generally put into cars and vans.
The first is a simple chip wtih a code which matches a code in the car / Van
The second is a chip which has a set of codes. They are read in order and the car / van remembers which one was used last. If you use the wrong code in the sequence then the car / van will ignore it and not let you start the engine.
The Iveco is unfortunately in the second group. If, like me, you snap your key, you can superglue a new key to the old and it works fine. The chip doesn't need to be "too" close to the barrel. Yes, it looks ugly, but it's much cheaper!
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
