Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Poulan wt200 "wildthing" gas leaf blower
Has been running fine for a year and a half then all of a sudden, it won't start. Checked and replaced plug, checked choke operation, checked mufffler to make sure it wasn't plugged up, put starter fluid in chamber and fired but only ran for a couple of seconds like it was on full choke then died.
What else can I check to get this thing started? It was only idle 2 weeks between uses when it started this problem
  • 1 more comment
  • Anonymous Oct 16, 2008
    same problem ..was running fine then wont start
    did a compression check and only has 60 lb...I was told by small engine mechanic it needs at least 90 to run.
    he also told me it was cheaper to buy a new one than to buy parts to try and fix it
  • tkelly901 Nov 11, 2008
    I had the same problem with my leaf blower. I found the head screws backed out from block. In other words, the head was loose. I put lock-tite on the threads and reattached the head. It is working fine now...
  • Anonymous May 18, 2009
    weak spark, won'tstart,got fuel to chamber
I need a cylinder Kit but can't find one anywhere
Posted on Jul 14, 2012
No compression wont start
Posted on Oct 16, 2008
Pour gas in carb. will run few sec. replaced both gas lines and filter.
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Mar 23, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Eng wont start, plug chngd, gas check good
could be lack of compression they won;t start with 60lbs
check if head bolted on tight
Nov 15, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Chaged gas and spark plug. Get no combustion
Make sure your getting a spark at the plug. Not much to these machines but verify good spark before anything else.
Nov 07, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan pro weedeater will start fine run untill you pick it up then dies
poulan has a bad habit of the fuel breaking inside the tank if it breaks before the fuel filter that makes the fuel line shorter
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Was running fine and just quit..checked it and found no spark
Assuming the spark plug is good, it is probably the ignition module.
Jim
Jun 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Gap setting poulan wildthing blower
buy an echo or a stihl... poulan rates this motor for 40 hours of use and then it is done.
head bolts came loose on mine piston slap wore out jug ring and piston. don't want to spend 40d on parts to repair a 100d unit
Dec 06, 2008 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
3,339 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
