Question about Maytag EPIC MFW9700S Front Load Washer
Sub message on unit
My Maytag gives me a "sub" message, what does that mean?
  • SIGNATUREREM Jan 05, 2009
    MY MAYTAG IS GIVING ME ERROR CODE SUD, WHAT DOES THIS MEAN, AND HOW DO I FIX IT?
  • 523 Answers
Sounds like suds lock
Posted on Nov 09, 2008
Why is my Maytag Epicz model #MGDZ600TW2 not starting amd giving me an error code F01. What does it mean?
F01 is a control unit failure does this come up when you push the start button or did you go into diagnostic to get this code I have seen it come up as a false code check the start button does it spring back like all the other buttons if so replace control if not the button is broke
Jan 29, 2015 | Maytag Dryers
Not sub but it displays suds on my 9000 maytag wqsher
My Kenmore washer does that too, it means there is too much suds in the tub so the machine will go thru a rinse type cycle to remove the excess suds. It should then go back to normal washing.
Jan 15, 2015 | Maytag Washing Machines
What does error message E01 and F09 mean?
Long drain something restricting water flow in drain cycle
Jan 10, 2015 | Maytag Washing Machines
I have the Samsung HTDS 1000 system and i get the PROTECTION error as soon as I open it. I've noticed that this occurs only when the 13 pin cable from the sub is connected to the main unit. When I...
The protection message appears only when a short is detected. Since you get this message only with the sub connected it means that the sub is shorted and you will have to repair or replace it.
If you decide to repair you should open it and test the electronics - amplifier and power source - of the sub.
Apr 01, 2011 | Audio Players & Recorders
What does an error message "F0" mean for kenmore model 911.41185991?
for a maytag the F0 code means a function key is stuck, and recommends changing out the touch pad, or touch pad and oven control assembly if one unit. google your model number for error codes.
Jun 21, 2010 | Ovens
My washer is not filling up and a code of LD is comimg up
Hello.
It sounds like you have a Maytag unit and it is giving an LD code which means that you have not opened the lid in at least 3 washes. If this is not the case, you will have to replace the lid switch assembly because it is not delivering the proper message to the controls.
Jul 15, 2009 | Washing Machines
Error message and alarm
These are the fault codes for your unit
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
650 sub zero that has a vacuum condenser message returns.
I have seen this many times and have fixed the problem many times. You may notice a ball of frost or ice build up in the fresh food compartment, This is because you have a leak in your evaporator coil and it needs to be replaced. It is a pretty costly repair but well worth it in consideration to what you paid for this unit or what the cost of a new one would be. Because it has less freon in it is why the compressor is running longer and causing message to pop up. Have the evaporator replaced in the section that is giving the issue and this will solve your problem with the unit.
Feb 26, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero model # 695 is flashing EC-40 error message. No ice.
When our Sub-Zero Model 650 quit making ice, and the SERVICE ICE lights started flashing, we called our technician who said, "You can pay me $178 for a service call or have another option - you have 2 seconds to decide. Oops, your time is up, I will decide for you!"
"Open the door and push the REFRIGERATOR UNIT ON / OFF message button; wait 30 seconds and push it again. About 95% of the time, the unit creates the glitch, and you are simply rebooting the computer. If that doesn't work, call me. I hate to take your money to come out to push a button."
IT WORKED! The warning message turned off and the freezer started cranking out ice.
Dec 18, 2008 | Refrigerators
Maytag EPIC MFW9700S Front Load Washer Logo
346 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
