Question about Sansui Audio Players & Recorders
Hi, Experts, Vintage Sansui 5050 receiver. FM works well in mono but no stereo sound or stereo indicator. Replaced stereo decoder chip but did not fix the problem. Rest of receiver works OK (AM, AUX, phono.) Cheers, Roger
  • analogdino Apr 08, 2013
    Problem solved! My very good tech friend found a transistor wrongly wired in the pre-amp. It looked factory fresh, so very odd... board may have been a prototype as there were other diferences from the schematic. Anyway, unit is now fixed and working well. Cheers, Roger
Mono is ok ....phil spector
Posted on Jun 07, 2009
Check for 19 Kz on stero decoder that requires calibration adjustment.
Instrument you need:
Occiloscope or frequezy counter and adj driver .
Good lock.
Posted on Jul 28, 2009
    Thanks, but not 19 KHz problem. See my comment above.
Model DV1531. Why is there no surround audio?
There is a decoding chip for surround sound. If it goes bad all you get is stereo. Happened to me with my Pioneer receiver.
Oct 27, 2015 | Audiovox Televison & Video
I have an older (10 ) years Sansui am/fm receiver model rz-5500av. It performs well, but after a power surge, the fm radio will not play in stereo. The fm stereo indicator flashes on and off. I was told...
Part of the circuit is a stereo multiplexer decoder, that decodes the fm stereo signal, I guess that is what you mean when you talk about capacitor linked to the fm band.
I do not have the sbchematics for this circuit, if you are good at electonics just grab the tester and check the whole circuit. On a radio is not difficult to find a blown capacitor.
Test also the stereo/mono switch.
Sep 21, 2008 | Sansui Audio Players & Recorders
No FM in vintage technics receiver
Connect a long wire/antenna wire to the respected fm antenna screw on the back of the receiver.
Mar 11, 2014 | Panasonic Vintage Technics Stereo Sa-500...
Marantz 2220b does not play in stereo in fm mode. i doxed all pots, & knobs, adjusted pot 304 but no dice. fm light is good, lites up on aux settings
Do you have an antenna attached to the receiver? If you don't, it might not be getting a powerful enough signal to pull in stereo. Also make sure that the mono button is not pressed or faulty.
Aug 26, 2013 | Marantz Vintage Model 2220b Stereophonic...
Sansui stereo remote
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Apr 27, 2013 | Sansui Vintage Am/fm Stereo Tuner Tu-217...
Meter fuse lamp 11/2 in 6.3 v 250 ma can not find one
http://www.ebay.com/itm/DYNACO-FISHER-MARANTZ-SANSUI-PIONEER-KENWOOD-JVC-OTHERS-HI-END-FUSE-LAMP-/370844118805?pt=US_Light_Bulbs&var=640100726899&hash=item5658082f15
Apr 18, 2013 | Harmon Kardon Vintage 70s Harman Kardon...
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
I have a 1977 sansui 7070 right channel only starts to work when balance is all the way to the right and 80% volume, channel works in mono any Ideas
The fact that the channel works in mono mode indicates that the output amplifier section is working correctly. The problem is in the front end. This can be as simple as a bad control, or the stereo separation circuit. Without seeing the unit and testing some components inside, this will be a difficult problem to solve remotely. The expensive parts are usually in the output amp section, so this repair should not be expensive from a parts perspective. I would budget around $20 for parts and have a repair shop take a look. I work on units of this vintage all the time, and usually the problem is a failing transistor or cap in the front end. Finding it is the problem not replacing it. Look for a shop with experience with this vintage.
Keep us posted.
Dan
Sep 03, 2009 | Audio Players & Recorders
Seems to only play in Mono
Karen - Is it only the FM section that is giging you trouble? Does Stereo work for the other inputs - VCR/DVD/Turntable?
Is that stereo button ONLY for the FM section?
May 13, 2007 | Teac AG-V3050 Receiver
1,296 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
