Question about Garmin GPS
Garmin Nuvi 760
Speaker not working
  • Garmin Master
  • 2,130 Answers
Please see the article I wrote on this issue:
http://www.fixya.com/support/r1094734-no_sound_or_garbled_sound_nuvi_series
- Jim
Posted on Oct 14, 2008
Flextone 3 one speaker not working
Then you either have a blown amp or speaker. Turn the amp off and move the wires from the speaker on the working side to the other speaker. If the other speaker works, you have a dead amp channel. if it does not, move the wires from the speaker on the non-working side to the other speaker. If that works, you have a dead speaker. Dead amp channel means take it to the shop. Dead speaker means buy a new one from Line 6 and install.
Mar 08, 2014 | Line 6 Flextone III Plus Guitar Amplifier
2002 Cheverolet Suburban Z71 - Left front speaker stops working, and unexpectedly will start working again until I turn the vehicle off. Next time I start up the vehicle, the speaker will not be working....
There can be a lot of causes of the problem, and it is difficult to diagnose. Can be:
- a bad speaker coil
- a bad wire connection at the back of the speaker
- a bad connector connection or broken wire in the wiring between the speaker and the amplifier/radio
- an intermittent problem in the amplifier/radio.
To try to fix the problem, start at the speaker (check the connectors, try a different speaker) and work back.
Jan 21, 2018 | Chevrolet Cars & Trucks
Pioneer DEH-P47DH Front left speaker not working, if i press audio button, i get no option to adjust balance, just fader. left rear speaker works and plays as loudly as right rear speaker. Huh? bad...
Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Nov 12, 2013 | Car Audio & Video
My HP 610 laptop's inbuild speaker is not working,but with the external speaker it is working.I want to know the price of HP compaq 610 inbuild speaker.
Try the following steps:
Open your laptop carefully (look out for fragile ribbon cables) !
Check for a broken wire going to the internal speaker.
Check for a faulty contact at the audio output jack (these things have a contact which disconnects the internal speaker when a plug is connected).
Temporarily connect any speaker in the place of the internal speaker.
If the problem is still the internal speaker, remove it and go to any good audio components shop and buy an equivalent speaker.
Hope this helps.
Nov 25, 2011 | Computers & Internet
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
My samsung s3310 speaker doesnt work
i have samsung s3310 but has no speaker problem pl solve this
Sep 16, 2010 | Samsung Cell Phones
It is an old speaker (DM601 S2) but well cared for. Have clear sound in one speaker and static in the other.
It sounds like a ground problem with the speaker crossover circuit or the amplifier. Turn the amp off and disconnect one speaker and interchange it with the other using the same speaker wires. If the static speaker is now working interchange the speaker wires and try it again. Or if the same speaker still has static it is the speaker. If the static is on the same channel then you have a bad wire or if both channels work it was a bad connection. If the problem remains on the same channel change the speaker wires. If the problem switched to the other channel then it is a bad speaker wire or connection. If the same speaker has the same problem it is most likely the crossover circuit in the speaker which is used to filter frequencies of the audio signal by using capacitors and coils. If the static speaker is now working and the other speaker is now not working it is the amplifier. If the static problem is on all input devices I would trouble shoot the preamp section of the amplifier.
Jun 23, 2010 | B&W DM602 S2 Speaker
Speaker randomly works
Please check the link: http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
Hope it helps.
Oct 25, 2009 | Dell Inspiron 1525 Laptop
Only one speaker works how do i check an see whats wrong with the other speakers.
First thing i'd do is to open up each speaker location and hot wire a working speaker to the leads (can be any speaker...from an old house radio etc as long as you know it works). If your test speaker works then the one in the car is bad. If you can't find anything there, then you can remove the radio and attach the test speaker to the actual harness. If you have power there and speaker works, then the wiring to the speaker needs to be tested. If it does not work you need another radio (cheaper than a repair.)
Sep 08, 2009 | 1998 Pontiac Grand Prix
One speaker wont work
if u have experience with the soldering of the terminals then you can open the speaker casing of the sub woofer and then solder the right speaker input wire.
dont do this if you have no previous experience and DISCONNECT THE POWER SUPPLY before doing any work inside.
Apr 19, 2009 | Logitech Z-2300 2.1 Computer Speaker...
GPS Logo
110 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
