Question about Poulan "Poulan" Push Mower
Mower shakes I changed the blade on my mower because I hit something and messed up the old blade. Now the mower shakes real bad.
  • 48 Answers
Sounds like you bent the crank - remove the spark plug , tie the shut off handle closed with a rope , then raise mower up so you can spin the blade . look at the blade bolt while you spin blade . if crank is bent the bolt will seem to wobble
Posted on Oct 17, 2008
How do you change a blade on a black and decker Rota-twin GR101 mower
my search shows that up as a
black and decker /flymo electric mower type
no picture on the parts list
of the rotating part being metal
two types of blade sets ...says its plastic and just clips on
is that for real ....plastic clip on mower blades
will this work
pull to the larger slot to release the old blade and back to the smaller slot to hold the new blade in place
Jun 15, 2016 | Cars & Trucks
Won't power up when clutch is engaged for mower deck
Something is binding in the mower deck area, perhaps and stuck bearing, bearing needs greased, stick or stone or big clod of grass caught between blade and deck or belt and pulley..
Disconnect to spark plug, and use a stick or something to spin blades manually. MAKE SURE spark plug is disconnected before EVER messing with blades. Motor could spin one time around accidentally and cut off your fingers. Disconnect plug wire and or remove plug to be absolutely sure before messing with blades. I'll say it again REMOVE plug wire from plug before inspecting blade area.
Apr 03, 2016 | Ferris IS2500 52"" Zero Turn Lawn Mower...
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
Why are my mower blades are hitting
did you hit a rock and bend something?did you change the blade and got the wrong one?
Apr 05, 2012 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Hi my lawn mower shakes so much it feels as if the enging is going to fly off.i did call a repair guy he said it sounded like a coil? is it posable for me to fix it? craftsman briggs & stratton 4.5...
Did you hit something with it? The blade might be bent, so try replaceing it. If the shaft is bent, the mower is junk, but if its just the blade being bent, its a cheap fix! The motor is NOT the cause of the shaking... Trust me on that one!
Sep 24, 2011 | Briggs & Stratton Garden
My helper was mowing with my Honda push mower.. The handle started shaking.. a lot.. It will start up at first pull but is not cutting well. The blade is turning but the mower is vibrating so much it...
it sounds like the blade may have hit some thing hard .
You say the blade is turning is it turning level or is it sort of swaying as you may have ofset the drive pin.
Worst case.. new mower as it can cost a lot of money to repair drive
I know as i have done the same thing a few years ago
Aug 02, 2010 | Mtd 22" Yard Machine Push Mower
I have a Poulan Pro push mower with a Honda engine that is leaking oil when it runs. Its model number is PR55N22SH It is three years old and never had a problem until now. any ideas where to start?
This mower sounds like it took a hit at one time and perhaps bent the blade, shaft?
If you had to replace the blade because it in fact did hit something then you would also want to be sure the sheer pin is ok, that is an easy test.... it goes like this, does it pull smooth when you are trying to start or does it backfire, shake, run raggy and at times want to pull your arms out of their sockets from the kick back?
Before checking the sheer pin you must determine if the shaft is bent(the shaft supports the balde) Raise mower off the ground, pull the spark plug out of the cylinder and turn the shaft, does the blade hit the casing underneath, if it does you are either buying a new mower or paying a lot to repair this one.
Also if any or all these situational events happened to the mower it is safe to say that the shaft oil seal is leaking on the bottom of the mower, remove plug and remove blade, inspect seal just above where the blade sits, its a round pressed rubber lipped seal around the shaft.
If it does all that then you need to pull the top cover and pull cord plate off the mower, take off the 3/4" nut left loosens, and check the sheer pin, its in the 1/4 wide x1/2 " long groove going down the shaft just below where you removed the 3/4 " nut, if its worn or partially worn pull the aluminum looking round cover off using a soft tap with a hammer to remove or a wheel puller and take the old sheer pin to Ace or the like hardware to match up a new one, install using the reverse proceedure, tighten the 3/4" nut to about 50 ft. pounds. Happy Mowing!!
Jun 11, 2010 | Garden
New mower hit small stump, cuts too low now/ can't adjust height
It is a bend blade. I feel your pain...I had a riding lawnmover that took a good two-hours to take apart and chage blades and 3/4 of an acre with old ornamental garden root balls popping up all the time. That was a long summer...
You may want to get the blade ahead of time so whomever can help you look under the mower can change the blade once they confirm it is bent. Even if they can fix the old one it is a blade you will need sooner or later and they are not very expensive.
Dec 17, 2009 | Garden
Lawn mower has a loud noise like something is hitting on metal part.changed blade this year with no problems. loud excessive vibration when running.
Sounds like your deck may be bent in and the blade is hitting. Remove the sparkplug and tilt the mower back on the handle (I'm assuming this is a push mower) and have someone pull the rope while you watch the blade underneath. You should see the problem.
Aug 06, 2009 | Craftsman Garden
Toro mower does not strat
Did you possibly hit something? Sounds like the flywheel key may have sheared.
May 18, 2009 | Toro Lawn Mower With Toro Power Tools
Poulan "Poulan" Push Mower Logo
695 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
