Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint Ultima DWF 70 code AL10
What does code AL 10 mean on a Hotpoint Ultima DWF 70 dishwasher
  • 19 Answers
SOURCE: Hotpoint Ultima dishwasher dwf70
Press and hold the start and the on/off buttons together. It should come out of demo mode.
Posted on Aug 26, 2007
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
  • 93 Answers
SOURCE: what does code al99 mean
AL99 is a communications error.
check PCB(s) cabling, connectors .
Posted on Jul 28, 2008
abhishek33
  • 1239 Answers
SOURCE: Manual for Hotpoint Aquarius dishwasher - DWF 34
hi
you want
Hotpoint Aquarius dishwasher - DWF 34 manual no.dont wory go to how stuffworks.comyou can get all info you want.please rate it
Posted on Nov 22, 2008
SOURCE: Hi, I have a Hotpoint FDW80,
fdw80 error code is the heater or module
Posted on Jan 14, 2009
My hotpoint ultima FDW85 - is displaying the code AL10 what does this mean (bought second hand with no manual
I believe that this means "Heater element open circuit" Symptoms are thayt the machine will fill with water but then will not wash because it's waiting for the element to start heating the water and it can't.
Jul 25, 2011 | Dishwashers
Our hotpoint fdw60 won't wash properly if at all water goes in but it does not seem to wash and we get a code of AL10 too
AL10 means open circuit in heating circuit. ie not heating which will also explain poor wash results.
can be a fairly involved job and should be left to someone who knows what they are doing.
on other hand could be as simple as a broken wire inside the door skin, just remove and give all the wires a good tug.
Jul 11, 2011 | Hotpoint Dishwashers
Model FDW80 error code AL-10 what does this mean?.
error code AL-10 == Failed heating element
You will need to have the element replaced, call a professional, or obtain a service manual and do a DIY?
May 12, 2011 | Hotpoint Dishwashers
Hi I have a Hotpoint fdw80 witch is displaying an error code AL10. Please can you tell me what this means so I can decide a course of action. Many Thank's Amanda
I found these error codes for the hotpoint fdw80
AL01 - Anti flood switch operated
AL02 - Valve or connections
AL03 - Time out - drain
AL04 - Thermistor (module)
AL05 - Circulation pump
AL06 - Time out - fill
AL07 - Not used
AL08 - Time out - heat
AL09 - Software recogntion error
AL10 - Heating circuit
AL99 - Communications error - connectors, cables etc.
H20 - Time out - fill (taps)
Now looking at AL10 error. Most often it is the heater element which is not effective due to scale formation. Make a solution of white vinegar and water (50:50) pour it onto the base of the dishwasher. Leave overnight and run dishwasher as normal. Somehow the vineger has to reach the heating element which is an inline heater. I am assuming normally you would use the hotwater connection from the kitchen tap.
If this does not help - depends how soon into the cycle you get the error you will have to replace the heater. I think it would look like this.
Feb 01, 2011 | Dishwashers
Hotpoint fdw85 dishwasher error code al10
Hi we've got the fdw80 and AL10 is the heating element. Ours goes wrong every couple of months luckyly we've got extended warranty till 2011. They wont replace machine as fixable so they will be coinng out every 2 months for the next 3 years.
Hope this helps
Feb 13, 2008 | Dishwashers
Alarm Code 10 - Meaning Please?
You can download the manual from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HB00503_WF840_860_865_19504206802_jan05.pdf
You will need to contact the service helpline for the explanantion of the F10 display
Dec 30, 2007 | Hotpoint Ultima WF860 Front Load Washer
Aug 25, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
174 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
