Question about GPS
SD Memory Card Software For NVX200
Hello, is there a place where I can get all the software that was preloaded onto the SD Memory card that came with the nvx200 unit? For some reason my memory card can't be read everytime I try to restore data, I keep getting a failure to load message. Please help, thank so you much in advance.
  • jpmismi12 Dec 13, 2008
    problem with card jensen gps nvx200
Please i need help my memory card got stolen and my gps is not working and all i need is the software because i have bought another memory card so please text back its a jensen nvx200 audiovox navigation and was online for hrs. looking for the softeare so please text back
Posted on Sep 02, 2009
My ds freezes when loading the R4, or it says that there is no game in the ds slot
Stuck on Loading Screen This usually indicates that the software kernel on the micro sd memory card has become corrupted. It can also happen if the micro sd memory card is overloaded with games, music and video files etc. The solution is to reinstall the kernel software on the micro sd card and ensure the micro sd memory card is not overloaded. Leave about 25% memory free.
download SDformatter and format the sd card with that, place all the files on there, none in folders..
  • Download the correct software kernel from the manufacturers website
  • Unzip the files using a suitable programme such as Win Zip or 7 Zip.
  • Open the folder containing the unzipped files and copy the 4 files (Moonmemo, Moonshl2, R4iMenu and R4.dat) to the root of the memory card.
  • At this point put the memory card into your R4 card. Start your console and ensure the R4 card is operating correctly.
  • You may have to run an upgrade file at this point
Mar 24, 2014 | Nintendo DS Lite Console
Tip
First Choice on doing anything on the Wii
The most important thing right away after you install homebrew is to install bootmii or preloader, as they both protect your wii from getting bricked.
if you are trying to install any ios or cios or even themes , its pure suicide to do it without both programs as those installations will eventually brick your wii.
these are the advantages of preloader and bootmii , (prefered choice is bootmii).
1-Boot mii: BootMii is a piece of software that can be installed as an IOS or inserted into the boot process. As an IOS, it provides a fast way to back up your Wii's internal NAND flash memory, and will eventually form the basis of a new generation of homebrew applications for the Wii. Inserted into the boot process, BootMii provides you with a "safety net" -- you can back up your entire Wii to SD in under three minutes! If you were to brick your Wii, BootMii would still run and let you restore your backup from SD, quickly and painlessly. BootMii also allows you to directly boot The Homebrew Channel or other homebrew from SD, bypassing the "warning screen" and the rest of the menu.
2-Preloader: Preloader is a small application which places itself before the System Menu. Its main feature is to directly boot the Homebrew Channel or a file you can install from a FAT device. Preloader is also able to apply memory patches the system menu to remove limitations or other things. Since Preloader places itself before the System Menu any problems that would cause the System Menu to fail are not causing your whole Wii to stop working.
If autoboot is enabled and you want to access Preloader's menu simply hold RESET while powering the Wii on
also
Preloader offers hacks as: install additional System Menu patches, simply copy the "hacks.ini" file included with preloader into the root of your SD card. (Ensure you are using the correct hacks.ini for your Wii's region.) Then, boot into Preloader's settings, and chose to enable or disable the patches in the Hack Settings menu.
Once applied, your patches are placed in NAND, so feel free to erase the file on your SD card.
The format for adding additional hacks, or patches, to your hacks.ini file is simple and should explain itself.
on Apr 23, 2010 | Video Game Consoles & Games
How can I restore deleted pictures from memory card
hi
i assume you have stored the pictures and data onto another source (ie: your hard disk drive) if so, simply place the card into USB or SD slot . select the images and drag and drop into the memory card.
hope this helps
Jul 09, 2011 | Computers & Internet
Navigon 7000T - SD card problem? Refuses to start up.
Sounds like the sd card is beginning to give you a problem, if you can find another sd card or just buy one, (they are less then 20 bucks now) copy the software from the original sd card and put it onto the new card. This should clear up the problem since it sounds like the cards lock is worn down to much for the sensor to feel it.
Mar 11, 2010 | Navigon PNA Transonic 7000T Car GPS...
How do you put video from your camcorder to your computer?
With a Canon ZR70MC camcorder, you can record video onto miniDV tape, or onto the SDmemory card in Card Camera mode.
To access video on the miniDV tape, you will use the DV cable (IEEE 1394 aka FireWire). Connecting this cable to your windows computer will allow you to transfer high quality video using the software supplied on the digital video solutions disc, or just about any other windows video editing software.
To access videos stored on the SD memory card, remove the card and place it in a card reader connected to your computer, or attach a usb cord to the camera and the computer. Video stored on the memory card is limited to 10 second clips @ 320x240 resolution.
Oct 11, 2009 | Canon ZR70MC Mini DV Digital Camcorder
R4i s card wont load
Download the R4 software,
Format the sd card, (copy any games and save files to your computer as a backup)
Copy the R4 software onto the sd card ,
should work fine i did this 3 days ago
Aug 07, 2009 | Nintendo DSi Black Console
Unable to read sd card
Hi grecko, Hope this helps, I've just bought a 4gb memory card for my daughter's ds so she can fit 58-60 games instead of 28 on a 2gb memory card and have downloaded and put a file onto the memory card before loading games onto it.
Supercard DS one have a site where you can download the files you need and it gives help. Guess it's the same if using an R4 supercard too but I bought an R4 card for partner preloaded with software.
May 14, 2009 | Nintendo DS Lite Console
The preloaded SD card for my Evesham GPS is bad. I need a new one
You can buy software on Ebay for uk Maps. Its a CD.Just copy the software onto an SD Card.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150362945965&ssPageName=STRK:MESELX:IT
Mar 28, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Garmin Streetpilot i3 GPS cannot load map to memory card
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
568 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
