Question about Car Audio & Video
2001 Nissan Sentra Radio
Hey Guys,
I have a 2001 Nissan Sentra Factory Radio, It has power. It now has terrible reception, the only audiio sound it hs is coming from the rear passenger speaker. If turn the volume up nothing happens. Any advice is apprectiate.
Thanks,
Wire color i can not find proper color
Posted on Nov 10, 2008
Speakers stopped working on my 2010 nissan sentra
Are all speakers off?
If so, then the head unit is the issue.
If we're only talking one speaker off, then check the wiring to that speaker.
You can connect an AA or AAA battery to the speaker wire, and check to see if the speaker moves. If it does, then the spring and speaker are fine. It's the head unit which is faulty.
Nov 12, 2012 | 2010 Nissan Sentra
How do you take a stock radio off a nissan sentra gxe 2001?
if you remove the stock radio you will not be able to re program the remote key fob or re set the service light
Nov 21, 2010 | 2001 Nissan Sentra
Nissan sentra 1400gx
Hey, i checked out the "PLATE" theory, i couldnt find anything in the nissan Database (sorry), if the parking lights work on the car, but not the BRAKE lights, it could be caused by the brake switch, Its located under the brake pedal, its a simple concept... when you hit the brake, the pedal hits a button to trigger the brake lights, its fairly common for these to go out, however, this wouldnt cause the dash lights to not work, you might try looking for a short in your wiring, Best of luck!
Mar 19, 2010 | 2003 Nissan Sentra
Dual xhd6425 Reception Problems
My XHD6425 seems to be very inconsistent... Sometimes I get okay reception, other times I get terrible reception (much worse than my original stock Ford radio). The reception problems are more noticeable on stations that are more than 30 miles away or so.
Perhaps oddest of all, I've sometimes had it bounce back and forth between two stations (like if you are driving and in the middle of nowhere, half way between two stations), even in areas where I know should be getting good reception on one station and had never heard of the other other station before.
If you've figured anything out, please let me know.
Jan 16, 2010 | Dual Electronics XHD6425 Car CD/ MP3...
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
BURN COIL PACK
you have shorted plug or wire let me know ok hey vote for me ok
May 24, 2009 | 2001 Nissan Sentra
Radio Problem
There is not an easy answer for this one. Some troubleshooting needs to be done. I have seen the Rockford Fosgate system in many of the newer Sentra's. Try hooking a known working speaker to a nonworking position. This will tell if it is a speaker problem. If the problem persists, this could be stereo or amplifier.
Terrible reception troubleshooting, a bad antenna will give poor FM and no AM. If both have bad reception, this is a stereo problem. You can remove the stereo from the dash, place a small pick tool or screwdriver into the antenna jack and test reception. If the reception problem clears, this is a antenna problem. I have seen car detailers pull the connector from the rear window antenna and forget to plug it back in too.
Nov 10, 2008 | Car Audio & Video
Car Audio & Video Logo
513 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
