Question about HP LaserJet 4650 Color Printer
Hp450n Upgrade Can automatic two-sided printing be added to a Hp4650N printer? (making the printer the equivalent to a HP4650DN)
    Problem Solver:
  • 11 Answers
NO
Is it not support
Posted on Oct 14, 2008
Printing on both sides
Make sure the Automatic Duplexing option is enabled:
Enter Control Panel then Devices and Printers.
Right click the printer icon, then Printer Properties.
Click the Device Settings tab.
Set the Automatic Two-Sided Duplex Accessory as installed and click OK to save.
Now Automatic Duplexing should become available.
My LaserJet 1320 will no longer do duplex printing with Windows 8
Aug 07, 2014 | HP LaserJet 1320 Printer
49.ff05 error
A 49 error on an HP printer is caused by the printer receiving a commmand it does not understand. It is the computer equivalent of "huh?" The first step to fixing this is to ensure that you have the most current firmware installed for the printer. Curent version is 02.120.3. To find what is installed, restart printer to clear the 49 error and then printer a configuration page. On the upper left hand side of the config page you will find the firmware revision listed. If it is not 02.120.3 then follow instructions below. You can print a config sheet by using the up or down arrows to change the menus until it displays information. Press checkmark and then on the next menu use the up/down arrow till you find configuration sheet and press checkmark again. You may need to ensure that there are no print jobs pending so that the printer does not have another 49 error while you are trying to do this.
Firmware upgrade instructions:
Click here to access HP site where you will find the lastest firmware revision. If you are using Windows, download the first option which is the EASY INSTALL. Run the file once downloaded and it will automatically start and confirm which printer you want to upgrade.
Mar 13, 2011 | HP LaserJet P3005d Printer
300 dpi in canon 2900B
I cannot understand how will print picture 300x300 dpi in CANON 2900B. There is solution but not working.....
Sep 13, 2009 | Canon LASER SHOT LBP-2900 Printer
Can't get the hp4650dn to print from tray 2 keeps defaulting to 1
Hi Im Ray.
1st check to see if the paper sensor in tray 2 has not got stuck.Take the paper tray out of tray 2 and look in and up right hand side there should be three levers that move up and down.
2nd have a look at the onboard menu and see if the default tray is set to tray 1.
Check onboard paper settings.
Mar 20, 2009 | HP LaserJet 4650dn Printer
Remove control panel
You may have to remove the right and left covers, but there is one screw on the left side of the panel and 2 screws on the right side and the panel should just lift off.
Feb 27, 2009 | HP LaserJet 4650n Printer
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
HP LaserJet 4650 Color Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
