My laptop - all programmes on the laptop cannot be opened this includes everything and internet the laptop says tis due to "specified file path or device cannot be accessed because of permission - cannot even open re-boot cd - can anyone help?
    Master:
  • 538 Answers
Maybe..you have a recovery disc..and it will not boot from that either...well..then maybe the memory or mother board are unhappy
Posted on Oct 13, 2008
Windows cannot access specified device path or file
Windows cannot access the specified device path or file. You may not have appropriate permissions.What's annoying about this message is that sometimes it has nothing to do with permissions at all! Here's a couple of possible ways to fix it, depending on your system.
Note: First, restart your computer in Safe Mode (only XP and Vista) and see if you can open the file or programs in question. If so, it's not a "real" permission issue, it's a program or process on your computer that is giving the error.
The best solution that has worked for most people is to simply uninstall Internet Explorer enhanced security configuration.
Method 2 - Turn off anti-virus or firewall If you are having this issue in Windows XP or Windows Vista, then your problem is probably related to an actual permission issue.
Norton Internet 200X, Bitdefender, AVG anti-virus, Trend Micro 200X can all cause this problem. If you have any of these programs installed, make sure to disable them and test it you can run programs, open files, etc.
If so, then you'll have to either use a different program or find something on the Internet about to how to configure your software to not interact badly with Windows.
The same thing can also happen with an overly aggressive firewall. If you are running Comodo firewall or something similar (other than the basic Windows Firewall), then disable that also.
Method 3 - Unblock the file If neither of those two methods worked, the file may be blocked by Windows. Note that this is only for Windows Server 2003 and higher.
When you copy an EXE file from another computer to a Windows Server 2003 box, there is what is called a blocked property set on the file. This is due to the increased security on servers.
Right-click on the file and choose Properties. You'll see a button called Unblock at the bottom.
Method 4 - Real permissions issue Finally, you may actually have a permissions issue. In this case, make sure you are an Administrator or you are part of the Domain Admins group if you are in a domain.
Also, you can try right-clicking on the file and choose Run As. Then type in the Administrator credentials and try to run the file. If you are able to run it, that means you account is not setup properly or is not in the rightuser group.
Feb 09, 2014 | Microsoft Windows 7 Ultimate for PC
Iwisoft swf to video failed to open file please help
I doesn't use the tool, instead I'm using the Kvisoft swf to video converter. I've used it several times already and it works in Flash to video conversion.
Aug 11, 2012 | flash-swf-converter iWisoft Free Video...
Once i open my laptop, this message is displayed on the screen : " Desktop! Could not load or run 'C:/Users/Bitkon/Local' specified in the registry. Make sure the file exists on your computer or...
You can run msconfig.exe from the Start Menu then search for that file in the Startup List and uncheckit. If you cannot start your PC becouse of this error, just manntain the Shift key pressed during boot to skip loading Startup programms, then do the msconfig.exe thing.
Mar 08, 2011 | Microsoft Windows 98 for PC
I have a dell pc, every time i drag a movie file to the portable drive, it says "Cannot find specified file. Make sure you specify the correct path and file name." What am i suppose to do??
Make sure you are not dragging a "short-cut" file - this is not the actual file. Locate the actual file and try that - verify it's the actual file by reading the properties extension such as ".mpg".
Dec 29, 2010 | Verbatim CLON Portable, 250GB, USB,...
How to delete internet files from C drive
C:\Documents and Settings\(This will be your user login name)\Local Settings\Temporary Internet Files.
Go to the path specified and do shift + delete to completely delete all the contents .
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | Acer Computers & Internet
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Windows cannot access the specified device, path or file.
Try to using Admininstrator user and passwor or the user id and password which have preveleges.
Thanks
Iqbal
Jun 16, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
