Question about Porter Cable 3" x 21" Electronic Variable Speed Sander
Porter Cable 352V belt sander eats belts
I have a very new PC model 352 belt sander. It consistently eats belts after only a few minutes of sanding. My first thought was "bad belt trackng" so I immediately checked the tracking on the newly installed belt. I set the specs exactly to the PC manual. No luck. The unit still eats belts. I inspected the sander components and they all look fine with no signs of damage or visible wear. This unit was purchased brand new and has only been used a few times so up until I changed the first belt, I had had no problem. Do you think the belts I'm using are the problem (Norton manufacture) or is it the sander itself?
Thanks in advance.
H. Robba
  • 1 more comment
  • harterobba Apr 03, 2009
    Thanks for all your input people!
    Deeply appreciated.
    Harte
  • harterobba Apr 04, 2009
    Thanks again to all who respond to this.
    It really helps.
    H. Robba
  • David Ford
    David Ford May 11, 2010
    are the new belts directional? they would have an arrow on the inside indicating which way to install. what side of the belt is getting chewed up?
    President:
  • 1,996 Answers
I've never had any particular problems with norton belts. All belts will require some adjustment as they wear in,however.
Try this: Put a new belt on, turn the sander upside down and rest it on the front handle. Get a good grip on the rear handle and turn it on while you use your other hand to turn the tracking adjustment. Just center the belt on the drum. I don't know what the manual tells you to do, but that's what matters, that the belt rides across the platen without hanging out loose in space or running up against the housing of the machine. If it does ride in against the housing, and you don't track it away, eventually you'll have a groove worn right through the side of the machine.
If you try this, and it still doesn't work, make sure the drums are secure and look right. Is it possible the machine was dropped and the drum bent? If so, parts will have to be replaced.
The only other cause I can imagine is that there is some kind of something jammed inside the housing that is protruding into the belt pathway that they're getting caught on, but that seems unlikely. Check anyway. Look with a flashlight.
There are better belts available than Norton, but they should work.
Some belts have an arrow on the inside of the belt indicating the direction of travel. Make sure if yours does, that you put it on that way. I try to install them so the joint will tend to ride up over the work instead of the work tending to want to tear the joint apart, but this is not always obvious, depending on the mfr.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • efs_perpends
    efs_perpends Apr 03, 2009
    It will help us a little if you give the answers a rating. Thanks!
Need manual for porter cable 352vs sander or chart of adjustmetns.
Posted on Sep 25, 2011
I have a Porter Cable 2'' A-2 belt sander and need
you can buy that gear from ereplacementparts.com you will need the type number off the tool to make sure you order the right one, they cost around 25.28 and for a type 2 the number is D839309
Sep 10, 2011 | Porter Cable 363 4" X 24" Belt Sander
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Sep 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
I need a new belt for my porter cable 4X24 inch belt sander - model 362 - type 6 whisper series
I have had the hardest time trying to find a belt for mine.
I've made do with a 3 x 24 without any turmoil
I take it you are having similar problems
Mike
Aug 21, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Replacing sand paper
Look on the side of the tool between the guide and drive wheels for a lever
Loosening or disengaging this lever will take the tension off of the belt so that it can be removed
If there is no lever, there will be a tension know on the front of the tool that you can loosen to remove the belt
Jul 05, 2009 | Porter Cable Tools & Hardware - Others
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 3" x 21" Electronic Variable Speed Sander Logo
403 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
