Question about EliteGroup ECS G31T-M Motherboard - Quad Core Support, Intel G31, Audio, Video, PCI Express, 10/100 Ethernet LA
New ECS G31T-M won't recognize IDE devices
New MB won't recognize and IDE devices in BIOS. Tried new power and ribbon cables. Just keeps ask for to insert boot media in floppy. I don't have a floppy installed.
Any suggestions?
  • burchb Oct 13, 2008
    Forgot about master at the end of ribbon. Swapped the HD and the DVD and I'm good booting to XP install right now. Thanks guys.
  • 1,879 Answers
Locate the boot options in your BIOS and set it to boot from the Hard Drive
Posted on Oct 13, 2008
  • 334 Answers
Tell the 1st boot dev to be hard drive hit auto detect button make sure u have jumpers on hard drive master then slave in middle one on cable ok update bios
The ECS P6STP-FL motherboard uses IDE (PATA) harddrives, and optical drives. (CD/DVD drive)
IDE 1 is for the Harddrive.
IDE 1 is the 40-pin connector that is closest to the Ram Memory slots.
(Only 39-pin are used, however)
IDE 2 is used for the optical drive/s.
IDE 2 is next to IDE 1, and is further away from the Ram Memory slots.
The IDE connectors on the motherboard, have a Cut-Out on one side. A small square cut-out.
This is for the Locating Lug, on the flat IDE ribbon cable's, connector.
This makes sure that Pin 1 in the motherboard connector, is lined up with Wire 1 in the flat IDE ribbon cable.
The Locating Lug shown in this example, is two 'ridges' that are separated. Some designs just use one solid block.
IF, there is no Locating Lug;
Look for the faint Red stripe, on the side of the flat IDE ribbon cable,
This stripe denotes the side, that number 1 wire is on.
Motherboard installed in computer case, the red stripe on that flat IDE ribbon cable, goes DOWN.
Down towards the Bottom of the motherboard.
When connecting to the Harddrive, and there is no Locating Lug on flat IDE ribbon cable, the Red stripe goes towards the power cable connection.
This applies to the optical drive (CD/DVD drive), and Floppy Disk Drive.
(34-pins for a Floppy Disk Drive. Cable is smaller in width)
Now, there is a different method of connecting a Harddrive, or optical drive, in relation to the flat IDE ribbon cable.
Depends on if the flat IDE ribbon cable is a 40-wire cable, or an 80-wire cable. You can use Cable Select setting on Harddrive/Optical drive; OR you can just connect the Harddrive, or Optical drive the correct way,
Is the Harddrive recognized in BIOS Setup?
If your question relates that the Harddrive is not recognized, post back in a Comment.
Also post the manufacturer ID information off of the Harddrive's label.
Example for one type of Western Digital harddrive;
Western Digital 80 GB harddrive, and IDE (PATA)
With this information I can find the Cylinders, Heads, and Sectors.
Then guide you in entering it in BIOS Setup, IF needed.
"Press DEL to run Setup"
Press the Delete key to enter BIOS Setup.
AS SOON AS you press the Power On button, start tapping on the DELete key.
Tap in 2 second intervals.
You will hear beeps. These are Stuck Key Error Code beeps, and it is YOU that is doing it. Ignore the beeps.
Best method for entering BIO Setup.
(The window of opportunity for entering BIOS Setup, goes by F-A-S-T! The above method will get you in)
Your problem statement leaves a hole in the time/space continuum.
Does not exactly state what your problem is
For additional questions please post in a Comment.
Apr 26, 2013 | ECS Elitegroup P6stp-fl Motherboard Cpu...
Wont recognize the primary master IDE. Do I need to replace the MB or is this a known problem. Have tried diff drives and cables...
Don't wish to down a motherboard manufacturer, as it isn't good business, but I would use a SOYO mobo for a frisbee.
You've indicated that the primary master IDE isn't recognized?
Is this by looking in BIOS Setup?
Have you tried to set the harddrive's parameters manually in BIOS Setup?
Set the Cylinders, Heads, and Sectors?
The Cyl, Heads, and Sec information for each harddrive can be found by looking at the label on the top of the harddrive.
If it isn't listed go to the harddrive manufacturer's website, and use the model number off of the harddrive, to find said information.
Example using Seagate harddrive,
Barracuda, Model number ST3500830A
A) 16,383 Cylinders
B) 6 Heads
C) 63 Sectors
Also depends on what flat ribbon IDE cable you're using.
With a 40-wire flat ribbon IDE cable the primary harddrive plugs into the Middle of the cable.
With an 80-wire flat ribbon IDE cable, the primary harddrive plugs into the End connector of the cable.
(Both styles of IDE cables have 40-pins. Actually 39 as 1 is not used)
(Look under the heading - Connecting Your Hard Drives)
Plus you may want to check the continuity of each flat ribbon IDE cable's wires.
Use a multimeter set to Ohms.
Due to the age of these cables they can go bad.
Jul 24, 2011 | Soyo SY-K7VME Motherboard
I have an ECS G31T-M motherboard with the following: INTEL Core 2 Duo E8400, 3.00 GHz 1333 MHz Socket 775 6MB, Thermaltake W0379RU 500W power supply, OCZ OCZ2G8004GK DDR2 PC2-6400 800MHz 2GB. My system was...
You seem to have tried everything. Is it possible for you to reload your motherboard drivers, particularly the IDE and SATA drivers. Maybe one of the SW drivers got corrupted. Hope this works.
Dec 15, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Need to know the location of the bios chip on a esc g31t-m v1.0 motherboard is it next to the battery? Failed bios flash want to remove bios chip to send in to badflash to have it reflashed.
Not all BIOS chips are removable. Your board uses a AMI Bios and u can quickly identify it by searching for the AMI symbol or lettering. If the Bios has a seat you can remove it: ttp://
If it is soldered on...sorry...u need a new MB.
But have you tried clearing the bios and then reflashing it?
Jun 06, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
I had a new G31T-M mainboard! I use it with intel quad chip! I followed the instruction in user`s guide but it can not start! it stops at screen with a note "press F11 to start BBS POPUP". Can u tell me...
go into control panel, open up the icon realtec hd sound effect. left click on audio I/O, left click on little blue wrenchtowards the top of screen. Put check mark in the box next to Disable front panel jack detection. exit out & plug into front asound it it will work, the back sound will still work to.
Sep 27, 2008 | EliteGroup ECS G31T-M Motherboard - Quad...
ECS G31T-M keeps rebooting problem system ECS G31T-M M/B Intel Video COMBO.. Intel Core 2 Duo E8400 Processor 3.0GHz (3.0GHz x 2) CPU 6MB L2 Cache 1333MHz FSB .. MassCool LGA 775 CPU Cooler /...
what was the software.... and if you can... boot into safe mode.... tap f8 when it starts it's boot up and remove the offending program....
Sep 06, 2008 | EliteGroup Computers & Internet
No picture at all
Hi geminip3, you need to make a couple bios changes when using a PCI-E graphics card. Still have your manual? Go to page 36. Advanced Chipset Features. Onboard GPU (Enable If No Ext GPU). By adding a PCI-E card this should be set to Disable. Than go to page 44. Init Display First (PCI Slot), set this to [PCI-E]. Read each page.
Than save your bios & exit. The system will auto restart. If you do not see display, wait about a minute & remove the monitor cable to the second out put slot. Some PCI-E cards need more power than the PCI-E motherboard slot can provide. You may find a power port on the PCI-E card. Some look just like the power cord for a floppy, others look like the power cord for an IDE hard disk drive. The latest ones are black in color & one end connects to an opened 4-pin molex (IDE power cord). Let’s address the onboard video card. (No PCI-E card attached). Back to page 36. Onboard GPU should be set to [Enable]. Page 44. Set Init Display First to [VGA/PCI]. Page 45. PCI/VGA Palette Snoop, set to [Disable]. I was unable to find where in the bios one can set the amount of system memory to run the onboard VGA. ECS manual is not the easiest to work with. Note: Ihave worked on other ECS MB's & though the above information has worked out ok for some, its not worked out for others. If the above suggestions do not work out, suggest you call ECS tech. I have emailed ECS stating their manual is confusing & asked for them to explain bios settings for VGA & PCI-E. Correct bios settings for your MB & user jrl1261's MB GeForce6199PM-M2. If the above settings do not work out. Don't fret. ECS wil get back to me & I'll post their email here.
Aug 10, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
945GZT-M: HD listed as third IDE master in bios
If the drive is set as Cable Select you are allowing the motherboard to detect where it is on the ribbon cable. If the drive is shown as Primary slave then the drive is on the wrong connector on the ribbon cable. If it is shown as secondary master than the IDE cables on the board need to be switched (primary to secondary, secondary to primary)
Apr 10, 2008 | ECS 945GZT-M (V1.0) Motherboard
Msi p4m800pro ide issues
No Boot (system does post) - Hard drives not detected • Check jumper settings on all IDE devices • Verify that IDE controller is configured correctly in the BIOS • Check to make sure that the drive is connected to the correct controller • Make sure drives are configured correctly for RAID • Verify Onchip IDE configuration for ICH5 SATA operation is set correctly • Test drives with different IDE/SATA cables
Dec 19, 2007 | Intel Motherboard
Replaced Motherboard HELP
So the HD is not recognized at all or do you see it in the BIOS? If you don't see it at all then obvious things to check are the power cable, and the IDE or SATA cable. If it's an IDE drive it's not too difficult to bend a pin while attaching the connector. I would check that. I'm guessing you did not change any jumpers on the drive. Last thing I can think of is to be sure the BIOS settings are correct depending on if it's an IDE or SATA drive.
Nov 19, 2007 | Dell Dimension 8400 PC Desktop
EliteGroup ECS G31T-M Motherboard - Quad Core Support, Intel G31, Audio, Video, PCI Express, 10/100 Ethernet LA Logo
350 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
