Question about Sunbeam 2370 MixMaster Series Stand Mixer
My mixer motor doesn't work - Sunbeam 2370 MixMaster Series Stand Mixer
  • 1 more comment
  • paddlewheel Oct 14, 2008
    I found the receipt and the warranty was still valid. The store took it back without the original packaging!
  • rahool6966 Dec 08, 2008
    How do you access the fuses inside the mixer? I see no screws
  • hillcountryq Feb 13, 2009
    My mixer (2360) will start...slowly...then quickly grind to a halt. I located a replacement switch/circuit board online ($11.95...Marbeck's), but now can't see how to dis-assemble the mixer to access and replace the switch! Help?
  • 101 Answers
Check and replace the plug fuse and internal fuse of the mixer
Posted on Oct 13, 2008
How to fix a kitchen aid mixer that does not turn off
The answered suggestion on this post might be able to help you:
Doesn actually turn off Mixer
Mar 07, 2015 | Food Mixers
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
250 watts k45ss classic stand mixer doesn't run
My first guess would be the speed control plate. It has three screws in an upside down triangular shape. The two screws on top control and adjust speeds 1 thru 6, and often times just one screw being out a 16th of a turn will shut the mixer off completely. I would venture that when you were removing the two stud bolts you moved the adjustment screws on the speed control plate. Remember that even a slight movement can shut down your mixer, take a phillips screwdriver and turn the top left screw one quarter turn while the machine is on, it can start on you so don't be shocked and jump with a loaded screwdriver in your hand at the back of an electrical device, stay calm, if no start then try the left screw a quarter turn, if it does not start go to a half turn on each screw, if still no start turn thr screws back to the start place and try the bottom screw a quarter turn left and right, if you do not start by now, then something is wrong in another place, go back to the brushes and take them out and check how you put them in, these are the two most common problems with a no start mixer. If this does not fix your problem or get the mixer to start please come back here with more info. If you motor raced in the first place then I would suspect the phase control board, but when it came back to normal speed it leades me away from the phase board. When the phse control board goes out the mixer only works at high speed. So please let us know so that we can help further.
Mar 28, 2013 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid wont start
The possible problems could be in no real order>>>
1. your power outlet in your house
2 the power cord to the mixer broken or shorted
3 the speed control plate inside the mixer needs adjusting or replaced
4 the carbon brushes inside the motor head of the mixer need replaced
5 the armature a motor part
6 the stator a motor part
The first four are easy fixes the last two will require a full tear down. but there are lots of things to test first. let us know.
Feb 22, 2013 | KitchenAid KSM150PS Artisan Series Stand...
The mixer simply doesn't turn on. Worked fine yesterday. Today it seems like it's just dead
HI.Let me jusk ask if yiou also tried to connet to another socket.Let me just clarify that the motor itself did not work /rotate as well.Prior to that situation,have you tried to mix more than what is the capacity of your mixer.If possible motor was overworked/that's why its coil was burnt.There. are possibilities then. First might be that the mixers terminals inside will no longer engaged properly that's why it opens the circuit.Second the motor isn't working because the rotor and armatures coil was burnt because it runs beyond its maximum wattage capacity that's why it draws much current beyond the rotors coil capacity.Did you mixed something heavy.the motor works heavier the last time you used the unit?
Jul 23, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have a KitchenAid Professional 600 Series 6-Quart Stand Mixer, model KP26M1XBS, which no longer works. I was mixing pretzel dough and the mixer stopped turning. I initially just thought it overheated...
Don't worry about the Worm Gear for now. You have to make sure that the Motor
is fully functional by itself: Remove the Transmission Housing Cover (4 screws) and
the two screws holding the Motor down. Lift the Motor off the Worm Gear and set it
on the side (be careful of AC voltages from the Motor and Control Assembly).
Select Stir setting and observe the motor shaft. Is the Motor running? If it is,
Select other speeds to see how the motor performs.
With the motor now fully functional, you can now check the Worm Gear Follower
for worn out/broken teeth. Remember the motor drives the Worm Gear, it then in
turn drives the Worm Gear Follower (you may have to remove the grease to see it)
The Bevel Gear sits right on top of the Follower and drives the Attachment Gear.
Jul 06, 2011 | KitchenAid Food Mixers
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Mixer works on high speed but not low. Brushes
Motor brushes are fairly cheap to buy. It sounds like the first place to start: http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/88/Default.aspx
Jan 11, 2010 | KitchenAid K5SS Heavy Duty Commercial...
My son thought the big screws on my kitchenaid mixer were menat to be unscrewed. He was surpirsed when a spring and something else popped out. He replaced the parts but now the mixer doesn't work. HELP
Hi, abarhum. I hate it when that happens. Your son must be a future electrician, because what he ‘discovered’ was your mixer’s electric motor’s brushes. It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. Do you know if he removed them both, or just one?
I'd suggest removing them again and making sure the brushes are facing in the right direction to contact the armature’s commutator. The concave contact face of the brush should be resting completely on the commutator. If your son turned it 90 degrees too much when he put it back together for you, it won’t' seat properly and the motor doesn’t get any juice.
It might be helpful to have your Parts List Manual on hand when you do this. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P, and select the last file listed under Parts List (4), KSM50PWH2.pdf (354.62 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. You’ll want to focus on Illus. No. 47 and 29, which is the brush holder and brush & Spring assembly.
Don’t be too hard on your son… I can remember doing something very similar when I was young and became an engineer… J
Good luck, I hope this helps. Howard, Burke, VA\
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 08, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My kitchaid stopped working. Is it worth getting
CARREN90 – You don’t provide a lot of information, which would be helpful in providing a rational answer to your question. What model KA mixer do you own? How old is it? Is it under warranty? What do you mean by stopped working? Do you mean the motor runs but the agitator doesn’t turn or the motor doesn’t run at all? The more information provided, the better the answer I can offer. That being said, if your KA mixer is less than 20 years old, it might be worth repairing.
First, there are only two reasons it stopped working - an electrical problem; the electric motor or one of it’s components has failed so it is not getting electricity (power) to run; or a mechanical problem – one (or more) of the transmission gears has failed, and although the electric motor may still run, the agitator is not turning in the bowl.
Either problem is fixable; depending on how intimately you wish to get acquainted with the internal workings of your mixer. If you are DITY type person and feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number select a file under Parts List and then check to see it this matches your mixer model. You can check the disassembly and reassembly of your mixer, along with all the parts. It can be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can provide you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances (again the more information you provide the better their answers will be to you) and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. If the estimates exceed the original purchase price, you might consider purchasing a new one, but that is a decision only you can make. Hey, Christmas is just around the corner!!
Good luck, I hope this helps! Howard – Burke, VA
If this solution has helped you, please rate it, thanks! hslincoln
Nov 28, 2009 | KitchenAid Food Mixers
Sunbeam 2370 MixMaster Series Stand Mixer Logo
352 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
