Question about Universal Remote Control MX-3000 LCD Touchscreen Remote Control
Stuck button My puppy bit the remote and the button to the left of Main is stuck. I cannot use the remote as a result. Help!
  • Anonymous Mar 19, 2014
    Have a 19 inch Technika DV3-T TV and mislaid remote in move. Watched Freeview using top buttons, then a DVD now no way of returning to Freeview as need the OK button to confirm choice. What can I do?
  • 23 Answers
All right. This remote is very complex. But if you feel it, you can try to open it to unstock the key. It's look like a pieces a very soft platic where all the key are bonded together. If you don't want to do it, just get a cheap universal remote control and program it while you make fix your nice one by a pro. it's alway good to have another remote just in case....
Posted on Oct 15, 2008
The selector button no longer works on unit or remote...AU...CD...Tuner ...etc. WHY???
If the selector button on the unit AND the corresponding button on remote has no effect, then the problem lies with the digital circuit responsible for changing inputs and not the Remote or the selector knob on unit.. I am assuming that the other functions do work.
That puppy needs to be repaired unless you can live with the input that it is stuck on. U might try unplugging the unit for a while and then replugging it. On some newer models this "reboots" the electronics and restores operation
Jan 19, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Remote control will not operate pioneer XV-dv990 changed batteries, now stuck on DVD player.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 22, 2014 | Pioneer Televison & Video
Puppy 10 Month was stuck with its mother,how high is the chance that she is pregnant?
very good chance. u could have birth defects if puppy gives birth
Apr 06, 2014 | Televison & Video
Volume, device inpute issues
Try new battery's in the remote, and check all volume buttons, one may be stuck down.
Mar 23, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Truck remote will lock doors, but wont unlock. tried new batteries in remote, but didn't help. Thanks for any help
Just put new rubber in my car remote buttons did not work there was a bit of rober stuck in there near the old button
Jul 01, 2011 | Chevrolet Silverado 2500HD Cars & Trucks
None of Tv controls on side of tv will not work and remote will not work
MAY HAVE A STUCK BUTTON SUGGEST PRESSING EACH BUTTON HARD AND SEE IF ANYTHING CHANGES. THE MAIN MICRO PROCESSOR IN THE TV WILL RESPOND TO BUTTON COMMANDS BEFORE ALL ELSE SO IF THERE IS A STUCK BUTTON NO OTHER BUTTONS WILL WORK AND IT WILL NOT RESPOND TO THE REMOTE.
Dec 17, 2010 | LG 42LC2D 42 in. LCD HDTV
My lg remote will not respond, and the menu icon popps up every 30 seconds and wont stop. it just started today. what the heck?
From your description, it sounds like the main board is acting up and or one of the buttons on the TV are stuck.
Unplug the TV for a few minutes. One at a time, try to push every button on the TV’s keypad to hear the micro buttons click, especially the MENU button. (It sounds like that is the one stuck down)
Put all of your remotes in another room. They may have a stuck button that is sending a signal to your TV that is causing the problem.
Plug the TV back in, don’t touch any button on the TV and or the Remote, and see it the problem is fixed.
If the problem is not resolved, then it sounds like the main board and the keypad need to be checked out to identify the failure. To check out the main board and or the keypad would require a TV tech.
I hope this information has helped you.
Good Luck.
May 26, 2010 | LG Televison & Video
Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Jan 07, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Draining batteries
probably caused by a short inside the remote, it will need to be replaced
Jul 13, 2008 | DISH Network IR Remote Control
Go Video DVD player remote has gone haywire!
it sounds like your remote has got damp or over time the dust builds up behind the buttons you should be able to take the controll apert and remove the buttons check the pads are clean and not greasy then wipe over the board with some clean cotton cloth where the buttons pads press on to activate usually its just a bit of grease but check their is no button jammed it sounds like this could be the case as you get a different response to pressing the play button so try this first then if dont work still clean the buttons and pads be carefull not to dammage the pads they should come out all together and have little black pads stuck to them make sure their xlean and grease free if this still dont work then you can get but make sure its not one of the cheaper ones a all in one remote this should solve your problem hope this helps
Mar 07, 2007 | GoVideo DV2150 DVD Player/VCR
Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
51 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
