Question about IBM Wheelwriter 30 Typewriter
Typing close to top of ribbon
My IBM Selectric II, after being cleaned and fixed by a professional, still wants to print at the top of my ribbon. I can see each word printed at the very very top. This forces me to retype each line to get the top of the letters to form correctly and be seen. Everything is the correct product and it corrects wonderfully. I'm just tired of retyping everything. Please help.
I aqssume that the top of every third letter is missing. There is an adjusting screw under the L. ribbon spool howerer you need a very small spline wrench to a make. it.
DickyO
Posted on Oct 15, 2008
My IBM Selectric II either does not type some letters or only partially types them. Sometimes the machine will type a letter and sometimes not. It happens no matter which ball is on the machine. What
First put in a mulyi part form, type on it if the carbon is ok you have have a ribbon problem. The ribbon may be very old or not properly installed or twisted.
DickyO
Sep 30, 2014 | IBM Correcting Selectric II
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
I have a IBM Model 5651 Memory Typewriter (Selectric II carriage), and I cannot make the ribbon advance while typing. If I turn the ribbon it will type until the ‘ink’ runs out. It’s just not advancing. ...
If this takes a selectric II ribbon the Spiked driver may be gummed up. Remove the ribbon,
find the latch that holds the ribbon mech. open, release it the ribbon drive should swing freely to the right, if not spray some WD40 on the pivot point, above and below the arm then work it back and forth it should free up.
DickyO
Oct 25, 2010 | IBM Office Equipment & Supplies
I have an IBM Selectric II. It types but does
The tab tensioner on the R. side is probably broken, not a bad job but you have to know how.
DickyO
Sep 12, 2009 | IBM Office Equipment & Supplies
IBM Selectric II Ribbon Not Advancing
First check to be sure that the ribbon is on the left of the shock wire where it comes out of the cassette, if that is OK then check the ribbon driver it should move freely and swing to the ribbon take up spool. Some WD40 will free it up. Also be sire the ribbon is winding in the direction of the arrows.
DickyO
Jun 15, 2009 | IBM Office Equipment & Supplies
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
Ribbon not advancing on Selectric II typewriter
on the left far side of the ribbon there is a white vertical post. the ribbon should be on the left side of that. also make sure you turn the ribbon the direction of the arrow (on the cassete) otherwise will need professional repair
Nov 18, 2008 | Office Equipment & Supplies
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
IBM Selectric III - ribbon won't turn
Make sure the ribbon cartridge lever is closed and that the ribbon is on the outside of the shock wire (where the ribbon exits the left side of the cartridge)
Jan 20, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter 30 Typewriter Logo
74 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
