Question about Garmin GPS
When i enter the address it displays message " do u want to simulate driving this route?" & regrdless i answer yes or no, it simultes. we tried everything ,like restarting ,putting it back to factory settings etc. wht should i do?
  • 101 Answers
If the device has a usb connector, connect it to a pc and download the standard software for garmin devices, look for an option to update the firmware/software of the device.
follow all instructions the pc gives you
Posted on Oct 13, 2008
How to recover my yahoo password
1.Use the Sign-in Helper to reset your Yahoo password and regain access to your account. For account security, we'll only display some of the options below. The Yahoo system determines which options to display based on factors like where you're signing in from and recovery info on your account. Mobile phone number and alternate email address.
  • Go to the Sign-in Helper.
  • Enter your phone number or email address.
  • Click Continue.
  • If prompted, enter the CAPTCHA code.
  • If you can receive text messages to the number listed, click Yes, text me an Account Key. If you have access to the email address listed, click Yes, send me an Account Key.
  • Depending on the option you've selected, Yahoo will send an Account Key to your phone or email.
  • Enter the Account Key that Yahoo sent in the field provided, then click Verify.
  • Select an account to reset from the list connected to your mobile number or email address.
2.If you have forgotten your Yahoo password and wish to use your security questions, head over to Yahoo's Contact page and select Password and sign in.
Under sub-topic two, select Forgot Password, under Recommended Option, enter your email address and click on Submit.
Click Next. If prompted, enter the CAPTCHA code.
Select Use my secret questions, followed by Next. Then enter the answers to your security questions.
If entered correctly, Yahoo will prompt you to enter a new password. Enter your new password and click on Next to finish your password recovery.
Feb 17, 2017 | Yahoo Computers & Internet
GPS System isn't working
could be a simulation settings was still ON mode, thats why it will not do tracking your way point.
Aug 08, 2008 | Dodge Nitro Cars & Trucks
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
My daughter is driving to ohio and after part of the way here, the gps stopped working. When she enters the address it says 'gps is off" but it is clearly on and working.
Check unders tools, pick settings, them pick system. Make sure the GPS Simulator is off. When on it will tell you the GPS is off when you add an address, and ask you if you want to Simulate driving this route. This is on my Nuvi 1370T.
Aug 12, 2011 | Garmin nuvi 1300 Car GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Every time I run the DSL-504 ADSL2 Ethernet Router CD disc to setup my internet connection, always get the dslultility.exe message say "modam not deteched....." but everything is...
To release and renew IP address, go to Start > Run. Type in CMD and press Enter. At the prompt, type in ipconfig and press Enter. This will display the adapter information such as IP address, Subnet mask, and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (192.168.0.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
Nov 06, 2010 | D-Link Computers & Internet
My nokia 5320 given same PIN CODE and lock code. Athough PIN CODE is unlock, lock code is not ok. Displayed "code error!". So, please answer me about how to unlock my nokia 5320 express music.
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Oct 30, 2010 | Nokia 5320 XpressMusic Cellular Phone
Why would one turn " GPS Simulator" on or off ? What does this do for me?
hi, you didnt mention what model gps you have, but most gps simulation do the same thing. if you have the simulation activated (some models are on by default, others are off by default) once you put in an address for the gps to guide you, the gps (if in simulation mode) will show you the coarse you will be taken, before you start out.
so if your in NY and plot a coarse for California, it will show you moving along the plotted coarse...thats going to take quite a while to view since the simulation will move along at what ever the posted speed limit is along the route, so its kinda like watching grass grow unless it doesn't take much to amuse the person watching the simulation. it is quite handy in that it allows you to view turns and intersections ect ect ect before you ever get to them.
hope this makes sense...let me know if i need to explain it better, but if you turn on the simulation mode then enter an address, you'll see what i mean.
bill
Aug 13, 2010 | GPS
VPN tunnel establish using FQDN for remote end point address
Yes you can do as you expect.
ScreenOS Concepts & Examples ScreenOS Reference Guide, Volume 5: Virtual Private Networks Chapter 4 -- Site-to-Site Virtual Private Networks
"Route-Based Site-to-Site VPN, AutoKey IKE" Example
"Route-Based Site-to-Site VPN, Dynamic Peer" Example
"Route-Based Site-to-Site VPN, Manual Key" Example
"Setting AutoKey IKE Peer with FQDN" Example
"VPN Sites with Overlapping Addresses" Example ScreenOS 5.4: http://www.juniper.net/techpubs/software/screenos/screenos5.4.0/CE_v5.pdf
ScreenOS 6.0: http://www.juniper.net/techpubs/software/screenos/screenos6.0.0/CE_v5.pdf
May 03, 2009 | Juniper Networks (SSG-20-SH-WW)...
GPS Logo
66 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
