GE 46GW948 Sound but no image
I've had a GE 46GW948 TV for 7 years, it worked perfect until yesterday when the image started getting out of focus and the colors when on and off, so I turned it off thinking that it was a bad signal issue. Try to turn it back on, and I could hear all the channels perfectly but no image (completely black). I could only see a pale blue line accross the screen and some other times a few small color dots on the screen.
Is this a complex projection/signal issue or could it be just the projection "bulbs" (red, blue green) that need to be replaced? Does this call for a technician? any Idea on the estimated cost?
Thank you
Juan
  • 1030 Answers
SOURCE: Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Posted on Jan 15, 2008
yankeegurl
  • 121 Answers
SOURCE: Color doesn't line up
you need to replace both convergence ic's they are located on your D board mounted right on the 2 big heat sinks you should either need STK-392-560 or STK392-510's you can find which one on stamped on the side of your old ic's. you can go to this sight and get them at reasonable prices plus picture installation instructions and free online tech support if you need help. By doing the repair yourself you will save between 4-500.00 for about a 45min repair
http://servicemanuals.vstore.ca/
Posted on Apr 25, 2008
racer7x
  • 42 Answers
SOURCE: I HAVE A HITACHI PROJECTION
Replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Posted on Feb 08, 2009
  • 205 Answers
SOURCE: convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Posted on Oct 16, 2009
barbu51
  • 566 Answers
SOURCE: Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Posted on Dec 07, 2009
Venturer Tv to Sky
It sounds like your TV is on the wrong input. Look for a button that says input or source. Depending on the TV this will either provide an onscreen menu to select an input or it will simply scroll through the inputs. Turn on the Sky box and run through the inputs until you see something that looks like your Sky Box.
Jul 26, 2013 | Televison & Video
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
HELLO AM TOMMY BERRY FROM CLEVELAND HTS OHIO, I HAVE A 42 INCH HAIER PLASMA TV, THAT I BROUGHT 11 MONTHS AGO , IT WAS WORKING PERFECTLY UNTIL THIS EVENING WHEN I WAS CHANGING CHANNELS AND THE TV WENT BLANK...
Since you still have sound, you haven't accidentally switched the TV to a different source, so I would say that something has failed inside. If you have had it less than a year, place a service request and maybe they'll come over and ifx it before football season gets going
Sep 06, 2008 | Televison & Video
GE Gemstar 46" model 46GW948
can you hear the starting or a noise from the back?try unplugging then put back.sound to me that you will need a tech
most probably the trippler going bad.
Jose
Aug 09, 2008 | GE 46GW 948 46" Rear Projection Television
I have picture and no sound
Try unplugging it for a minute. You will have to go through setup again (most likely).
Some of these sets have a (software?) issue and the audio drops out maybe once or twice a year-at least that's what I've experienced. No real fix for it.
Aug 01, 2008 | GE 35GT720 35" TV
Ge projection tv
can you hear the tv starting on or a noise from the back
it may be the trippler or the power supply
Jun 14, 2008 | GE 46GW 948 46" Rear Projection Television
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
May 29, 2008 | Televison & Video
Lost code kenwood auto radio
Hello, I`ve lost the code nummber for my Kennwood Radio. Trying very hard to recive the code number but nobody can seem to help me.Any ideas ?
Mar 07, 2008 | Kenwood KDC-W5534U CD Player
GE 46GW948
you should just need to go from the audio o/p of the tv. to the amp. now the tv will have either fixed or variable audio out. if fixed ok, if variable, you just need to know that the volume out of the jacks in the back is directly related to the volume of the tv, so you will need to keep the tv volume up a ways. now on the amp hook up to an available input, make sure that the input you use is set to recieve an analog signal. this is very important. every amp is different you may need to read the manual on how to adjust the input from analog/digital/audo. good luck.
Jan 08, 2007 | GE 46GW947 46" Rear Projection Television
Open Questions:
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
