Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
My panasonic remote won't work. the lcd on the dvd shows set 1 everytime I click on it
  • sarai25 Jan 04, 2009
    Mine is the same, it shows channel 3 and lights up the TV infra red light but nothing happens.
  • dwlkr Apr 05, 2009
    whenever any button on the remote is pressed the recorder displays "DVD 1" and will give no other response. I have tried brand new batteries to no effect. The Player works perfectly well using it's panel controls. I cannot find any little switch on the remote as described by the other solution
I have had this happen nore than once. If you press the 1 button and hold it down. At same time press and hold the enter button for 2 or more seconds. Your remote will now be set to the system. Some models have a device code of 2 or 3. If your not sure what your device code is start with #1 device code.
Posted on Apr 13, 2009
My panasonic dvd recorder remote model dmr-es35v shows set 1 and remote wont work
Posted on Feb 09, 2009
This happened to mine today and i didn't realize that when i slept on my remote overnight. i had the same problem as i had the infrared hook up and a flashing light to let me know this, but i couldn't control anything. i found out that i accidentally switched over the little switch that has normal on one side and ID on the other. flipping this back to normal took care of my problem.
Posted on Feb 28, 2009
  • funbag lover Feb 28, 2009
    i just read what i wrote, i'm a ******* :). i meant to say that i found tis out after sleeping on my remote overnight. lol.
"SET 1" Displayed and remote not working.
You have a Panasonic, they have a feature, in case you have two or three Panasonic units you can program the remote either be used on one, two, three. So if the display lights set one that means the remote control would control set one. There are several ways to change a setting one is in the player menu, I believe you can change the remote. Check your manual, this is not a big deal.
Oct 18, 2014 | Panasonic Televison & Video
I GET SET 1 EVERYTIME I PRESS BUTTON ON CONTROLLER
Set remote to 1 by pressing 1 holding Ok/Enter for 3-5 seconds.
Jan 30, 2011 | Panasonic DMPBD45 BluRay Player
Dont work with remote control, shows SET I, I also used the rcontrol to turn on a Panasonic TV
This problem is caused by having more than 1 panasonic product using remotes, the remote may need to be reset say to set 2. I had this problem. It will tell you in the user trouble shoot guide to press and hold ok button down with the number button say 2 for several seconds, that should put the remote to to the correct setting.
Hope this helps
pete
Nov 06, 2010 | Panasonic DMRES15 DVD Recorder
Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
Sep 30, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Jun 05, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Jan 26, 2009 | Panasonic DMR-ES25 DVD Recorder
Hi, when i press any key on the dvd recorder remote (panasonic dmr-e55) i comes up with remote dvd 1 everytime and wont do anything else, weve tried umplugging it 2 but that doesnt help, do u have any...
Very easy fix.
Your DVD recorder can be set up to accept remote contol signals on any one of three channels. DVD 1, DVD 2 or DVD 3. Your remote can be set up to send signals on any of these channels. You need to make sure your recorder and remote are set to the same channel.
Your recorder is telling you that it is set to receive remote control signals on channel DVD 1. This means your remote control is currently set for a different channel.
Assuming that you have a genuine Panasonic remote, do the following, On your remote press the "Enter" button and hold it down. Then press the "1" button at the same time for two seconds, then release both. This will change your remote so it sends signals on DVD 1 which will match your recorder.
Those clever people at Panasonic realise that you will be delighted with their products and will probably have several of their appliances in use. The different channels avoids switching all your Panasonic gadgets at the same time. Clever huh?
Best wishes
Dec 29, 2008 | Panasonic DMR-E55 DVD Recorder
I HAVE DVR RECORDER
i had the same problem. press enter, hold it down and press and hold 1 for about 10 seconds.
Jan 18, 2008 | Panasonic DMRES15 DVD Recorder
Set 1
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
Jan 14, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
1,408 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
