Lh-t551 i've buy lh-t 551, but I can't find any firmware for it. I need it because that home cinema system can't read video files from usb drive! is there any solution for that kind of problem?
  • 1 more comment
  • hkarslig Nov 04, 2008
    did you find a way to solve the problem?
  • aifodor Nov 11, 2008
    i can't play divx movies from usb drive, but mp3 files are avaiables
  • Anonymous Apr 26, 2009
    i've buy Zenith DVT721 Home Theater System, but I can't find any firmware for it. I need it because that home cinema system can't read video files from usb drive! is there any solution for that kind of problem?
No use can not play divx files from usb eventhough I used lh-t771 firware which compatible to 551
Posted on Nov 11, 2008
I have a panasonic blu ray home cinema system, it says my usb isnt compatible cannot read it, trying to play music via a portable hard drive
It may be in the wrong format, there are 2 main format for usb hard drives, FAT32 and NTFS. You may have to reformat to a different format to what you currently have. To do this, you will need to plug it into a computer, go to Computer and right click on your drive and select format. Select either FAT32 or NTFS, make sure there is a tick in Quick Format and then click start. Please note, this will erase all data off your USB stick so make sure to copy all your data to your computer before you do this. If it doesn't work, then try the other format i.e if FAT32 does not work try NTFS. And just as a side note, the main difference between the 2 formats is FAT32 will not allow you to copy files over 4GB while NTFS will.
Dec 05, 2014 | Panasonic Audio Players & Recorders
Tip
LG LH-D6235 DVD Manual Download
Download LG LH-D6235 Home Cinema System Manual
Would you like to review the features of the LG LH-D6235 Home Cinema System?
Have you lost your LG LH-D6235 Home Cinema System Users Guide?
Would you like a digital, searchable, pdf version of the LG LH-D6235 Home Cinema System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the LG LH-D6235 Home Cinema System documentation.
I hope that helps.
____________________________________________________________________
LG LH-D6235 Home Theater Region Free Fix
on Jul 14, 2010 | Televison & Video
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
on Jul 14, 2010 | Audio Players & Recorders
Lg lh t551
pre amp set to low
Sep 01, 2014 | Audio Players & Recorders
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
Tip
LG LH-D6235 Manual Download
I hope that helps.
My lg lh-t760sb does not read all types of dvix video files
Why is my home theater system quickly began to see the screen flashing and striped. The sound is good. SCART connector is OK, I checked other devices. My TV has no HDMI but it is LCD. I bought it 3-4 years ago.( ONN ) If you know. So where can be a problem? Thank you.
Jan 16, 2010 | LG LH-T760IB Theater System
Tip
I hope that helps.
1,392 people viewed this question
 Grubhead
Grubhead
