Question about HP Compaq nc6320 Notebook
Power on password
Hello , i·ve HP NC6320 & i want a reset the power on password . could u gotte me 1 solution plz
  • gionaty Jan 08, 2009
    reset power on password
How to recover the bios/cmos password on my hp compaq nc6320 t5600 1.83ghz ?
To reset the BIOS password read the information from this link.
In case of your HP Compaq laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 26, 2010 | HP Compaq nc6320 Notebook
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
Need help forgot password for HP Compaq NX7330
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Please rate me .
Thanks .
Jul 29, 2009 | HP Compaq nc6320 Notebook
Pl,ease help....
plz check the website for more information
http://www.tech-faq.com/reset-bios-password.shtml
Sep 03, 2008 | HP Compaq nc6320 Notebook
HP Compaq nc6320 PC Notebook Problem
Try unplugging internal battery for a minute or two it worked for me.
Sep 01, 2008 | HP Compaq nc6320 Notebook
HP nc6320 BIOS Power on Password
You Have to Remove RTC battery ( Cmos ) battery.
Wait approximately 5 minutes
Replace the RTC battery and reassemble the computer
Connect Ac Power to the computer. Do not reinsert any batteries at this time
Turn On the computer
all the passwords and all the cmos setting have be cleared.
Aug 12, 2008 | HP Compaq nc6320 Notebook
Describe your HP Compaq nc6320 PC Notebook Problem
i have a Compaq nc6320 when i plug in the power cord the electricity led doesn't want to turn on i have changed the cords and the adapters and i doesn't power on or even charge the battery, did any one have an idea what to do in this problem?
Mar 31, 2008 | HP Compaq nc6320 Notebook
HP Compaq nc6320 pc notebook issue
it seems that its a not a problem with your hard disk at it load on to the windows succesfully. Chances are any one of these :-
1. Some one might have changed the user name or password.
2. The file that holds the password might be corrupted.
3.If you are using a network based login, ask your administrator for assistance.
The better solution is to Repair install or Re-Install the operating system...
( U might Lose your Data while doing it but not all the time)
Mar 28, 2008 | HP Compaq nc6320 Notebook
Password reset
Mar 24, 2008 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Notebook Logo
235 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
