Question about Lenovo Thinkpad T60 Notebook
How to format and install a OS into the HARD DISK using a PEN DRIVE ......
My CD drive is not working and i have been using Windows Vista in my laptop. I want to install Windows XP in it. Is there any way to format and install the OS into the hard drive using a PEN DRIVE ????????? Because I have only a PEN DRIVE, WINDOWS XP dumped in it and this INTERNET connection only. I don't even have a FDD also. Please suggest ...............
  • LaxmiCnu Oct 13, 2008
    Are you saying it is impossible??????? If so is there any other way???????? and I have a PC also with me. Is it possible to do from it ?????????/
  • nicedream Dec 26, 2008
    60 mb Thinkpad T60, 5 nb wasted on hidden partition. Not needed because I have great backups. Any I deas?
    Master:
  • 538 Answers
Nope..that is a complete compatibility challenge of the first order..
Posted on Oct 13, 2008
One I have to insert my pen drive in friend lab tab that Os is Vista that time pen drive ask formate ur drive I gave formate command on that time of my pen drive is not working Locked my pen drive is...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Oct 29, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Laptop wont boot...it wont load past the very first boot screen where it asks you to hit f12 for boot menu and f2 for system utilities it have the windows vista OS...is there a problem with the hard drive?...
Windows is corrupt...reload Win OS....if possible re-install Windows in a different partition say D: or E: etc (if u have more than 1 partition) and then once done let it boot from that and let Win load....take a full backup of all of your critical data to a USB pen drive....then reload Win CD in the Cd drive, switch off and switch on PC let it boot from CD and delete all partition on HD, format the disk fully and repartition the disk and load Win in C:
pls leave a feedback
Mar 03, 2010 | Toshiba Satellite A135-S4467 Notebook
How to format hard drive
To format any extended or external hard disk
Right Click the drive (example D:\ )and select the FORMAT Options
Click START to Format the Hard Drive. The time to format depends on size and the condition of the Hard Disk.
Feb 15, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Want to FORMAT hard disk with PEN DRIVE
you need to copy an operating system installer to your pen drive...
like for example you want xp or xp sp2, xp sp3, vista, r window 7..
you need it's installer cd and copy it to your pen drive...
if you want you can try searching for sites that you can download an installer..then save it to your pen drive...make sure you will copy the right application with bootable exe...so that you can format it your boot menu..
try this site it looks like reliable.. but i never tried downloading xp installer before that's why i don't know the circumstances that may happen...
i know it is about 2G + in size that's why i'm advicing you to buy a new one or if you have one just copy it to your pen drive through other computer with cd drive..
i hope i've helped you on this matter..
Feb 08, 2010 | Computers & Internet
Windows ce core 5.0 and we just bought new netbook called delstar and i try to get new windows but it wont work ! how it work with it without cd drivers! i puzzled this computer is limited!
if it has a USB port then u may use a pendrive and change the boot seq in BIOS to boot from USB drive
in the pendrive u must have all the WinXP OS install files...
use another PC having USB slot and a CD drive,
first make a pen drive bootable by formating it and copying the system files....(check what's the drive letter in which the pendrive is shown on MyComputer...it will be listed as "Removable Disk")
Note the drive letter say D: or E: or G: etc
then go to
Start / Run type
cmd
u will get a new black window
in the black window type
cd..
again type
cd..
u will go to c:\>
here type
cd windows
it will take u to
C:\Windows
here type
cd system32
so now it will look like this
c:\windows\system32>
here type
format e: /s or G: /s or E: /s based on the drive letter that u noted earlier
use another PC to just copy all files form a WinXp install CD to that formated pen drive and use that to boot your above PC that does nto have CD rom drive to install the Win OS
Jan 22, 2010 | Computers & Internet
How to install winxp on cybercom fid2010
try other bootable cd like linux live cd;if they are bootable then the problem lies with ur cd rom;usually laptop have the problem;if the laptop support booting from network;then Remote installation server will do it
Nov 27, 2009 | Computers & Internet
Stepbystep procedure for formating
Hello jerapur_123 What you'll need:
  • Recovery CD or Restore CD from the MFG
  • WIndows Operating Disk 98 or ME, 2000, XP or Vista.
  • A CD Rom Drive
  • Or a Floppy for low level formatting.
Key Steps to Formatting
Back it Up!
Before the format process, you want to make sure that if your goal is hard drive recovery, you back-up as much personal data and information from your hard drive as you need. In some instances where a virus has caused serious system damage, this may not be possible, but if your format is planned ahead of time you certainly can copy and archive data off your hard drive before you start the format process.
How to Format
If you purchased your computer from systems vendor such as a Dell, HP Compaq or Gateway system, you most likely will have a set-up or a restore-and-recovery CD (also referred to as a master CD) that came with the system. If this is the type of system you use, then a format is an easy process as the master CD by inserting the CD into your CDROM, will format the hard drive, reinstall your Windows operating system, and install any software and programs that came with the system. If you no longer have your master set-up CD, you should contact the manufacturer to get a replacement.
How to Format without a Recovery Disk:
If you aren't using this type of mass-market system, then a hard drive format will consist of you formatting the hard drive manually, installing your Windows OS from CD, then installing your software programs and hardware drivers. Before you begin the formatting process, it is important to make sure you have all your driver CDs located, Windows CD and your software CDs to ensure a smooth set-up.
It's also important to know about your operating system before you format. For example, if you're going to be reinstalling an older version of the operating such as Windows 98 or Windows ME then you should have a Windows 98 or ME start-up disk to complete the procedure. In this instance, you would restart the system with the start-up floppy in the drive. Upon system boot, you will choose to have CD-ROM support. Once the files load you can then choose to run the format command on your main drive (usually C drive). If you are using Windows 2000, Windows XP or Windows Vista the Windows installation process offers "format your hard drive" as an option. Here you would ensure your computer is set to boot from CD-ROM (a setting in your system BIOS), insert the Windows CD and restart the computer. From there you will be on your way to reformatting.
As you can see there are many options to formatting a hard drive. Hopefully this gives you a good understanding that most of the operating systems today do the formatting for you, all you need to do is pick that option as you follow the onscreen steps when you install either your Restore, or Operating System.
Good Luck,
Mark
Please don't forget to leave a rating.
Feb 18, 2009 | HP Computers & Internet
How to format a pen drive?
I know about this problem and the solution.
First, you should know your pen drive is infected with a virus. You can't usually repair it, you'lll just have to format it, and I'm getting to that.
Now, Before you format the pen drive, you might want to preserve some files in the drive?
Instead of trying to view the pen drive by double clicking or right click=>open TYPE the ASSOCIATED DRIVE LETTER at the RUN DIALOG BOX (start=>run)
Eg:
If your pen drive is assigned to drive E:
Start=>Run
Type "E:" (without quotes) and hit enter.
It should open.
Now you will probably see some weired .exe file, probably named fun.exe. That's the virus. You just cant delete it. BUT you can copy the rest of the imprtant files to your hard drive.
TO FORMAT
Start=>Run
type "cmd" (without qoutes) and hit enter
type "format/x E:" (without qoutes and mind your spellings and spacing. REPLACE "E:" with the associated drive letter of the pen drive)
Hit enter.
Hope my info fixes your problem,
Thanx for using fixya.
Sep 30, 2008 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Lenovo Thinkpad T60 Notebook Logo
170 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
