i have the same problem after downloading yahoo messenger 9 it will not open and can not remove it either cause it freezes up and i have windows xp not vistai have the same problem after downloading yahoo messenger 9 it will not open and can not remove it either cause it freezes up and i have windows xp not vista
contacted Yahoo They don't think there a promblem, Can't remove Yahoo IM 9 at all!!contacted Yahoo They don't think there a promblem, Can't remove Yahoo IM 9 at all!!
Yahoo messenger wouldn't open. Instead, when I click on it nothing happens. When I check task manager I see yahoo messenger using up 100% of my cpu.
When I try to uninstall, it freezes up at ft60.dll. What to do?Yahoo messenger wouldn't open. Instead, when I click on it nothing happens. When I check task manager I see yahoo messenger using up 100% of my cpu.
i installed messenger 9.. its completed about 99% after that it frezeed long time... i installed messenger 9.. its completed about 99% after that it frezeed long time...
AnonymousFeb 10, 2009
evn i have the same problemevn i have the same problem
AnonymousApr 25, 2009
yahoo messneger dows not start & unable to uninstall through add/remove yahoo messneger dows not start & unable to uninstall through add/remove
You can't post conmments that contain an email address.
Goto control anel add remove prog delete messenger and download again get from download.com better use DAP accellator for fast download you get free from www.download.com
i uninstall my yahoo but i didnt restart the pc after unistalling - This can be a normal issue and may be the version you installed does not require you to Restart your Computer so you can ignore this.
due to an error occured in opening a file while downloading - This error is normally occured because of the disconnection of Internet while the file was being downloaded. You need to make sure that the file is completely downloaded before you start installing it.
or if you want you can try to download it and install it again and then uninstall it because it seems to me that the yahoo messenger uninstaller is corrupt.
yahoo messenger 9.0 was not loading for me....so i tried to re-install it..tht ddnt work...thn i deleted all the files manually and removed the program... but now wen i install it it stops at 99%..i saw somewhr a suggestion...it helps to reach 100%but again the loading prob.. so in short nothing worked out.. i tried several times to install... it stops at 99%.... YAHOOOOOOOOO plzzz help. i use windows XP.
yahoo messenger wont open says a problem caused the program to stop working
everytime i try to start it up it says it isn't reponding
i can not get yahoo messenger 9 to open every time i di it goes duh duh duh what can i do about it
I have the same problem and have removed and reinstalled twice. no joy!
i installed yahoo messenger 9 and it will not open and when i tried to unistall it it freezes up..
pls....give me a solution...
thanx.
