Question about Symbol DS3407 Barcode Scanner
Symbol DS3407 How to set up Symbol DS3407 on PC? When i plag it to usb port it automatically found driver, but when i run SSI SDK sample DS3407 not responding.
Wher can i found Simple COM Port Emulation USB driver version 1.8.6
Have your tried the driver provided at
www.driverscape.com/download/symbol-usb-com-port-emulation
It says tis 2.33mb. Even if it turned out to be a driverscanner, simply install and wen it find the driver you are looking, use the ID to search for it on google and if it can installed directly.
Good luck
Nov 14, 2014 | Symbol LS2208 Handheld
I cant load my pictures in my computer
If images cannot be imported automatically into the Windows PC, check [Precautions] below.
[Precautions]
- Temporarily terminate resident software such as antivirus software.
- Connect the AC adapter or load a fully charged battery into the digital camera.
- If RealPlayer 10 is installed, select "Tools" - "Preferences" and then disable "Automatic Services."
XXXen the digital camera is connected to the PC, if the FinePixViewer starts up and images in the digital camera are displayed, skip Steps 1 to 5 and start with Step 6.
1. Start up the PC and then connect the digital camera and PC using a USB cable.
2. The "USB MODE" setting of the digital camera may be set to "PC CAM."
Set "USB MODE" to "Card Reader" or "DSC."
*Only in the case of the digital cameras that have the "USB MODE" setting in the SETUP menu
3. Check whether or not any mark indicating the USB connection (USB, CARD READER, USB symbol with an arrow mark, etc.) is displayed on the LCD monitor of the digital camera.
If not, the digital camera and the PC are not connected properly. Check the following points.
a. Restart the PC, disconnect and connect the USB cable and then try again.
b. If the PC has multiple USB ports, connect the USB cable to another port and then try again.
If no mark indicating the USB connection is displayed even after performing above Steps (a) and (b), the digital camera or USB cable may have a problem.
4. Check whether or not "Removable Disk" is displayed in "My Computer." (For example, when the operating system is Windows XP, a FinePix icon in the shape of a digital camera is displayed.)
If "Removable Disk" is not displayed, install the USB driver again.
5. Automatic startup software (Exif Launcher) may not function properly.
Perform the following procedure.
[Windows XP]
a. Select "Start" - "My Computer."
b. Right-click the "FinePix" icon and then click "Properties."
c. Click the AutoPlay tab.
d. Click "Music files" and then select "Pictures" from the displayed list.
e. Select "Select an action to perform."
f. Select "Viewing images with FinePixViewer."
g. Click the "OK" button.
6. The Automatic Save Settings may be incorrect.
Specify the Automatic Save Settings again by following the procedure below.
a. Start up the FinePixViewer.
b. Select "Automatic Save Settings" in the "Settings" menu.
*If "*** not found" is displayed, click the "OK" button.
c. In the "Way of Saving" column, click the "Browse" button to specify the storage location.
Feb 26, 2014 | Fuji FinePix A345 Digital Camera
Restart a tablet when it is locked
  • Connect the tablet with USB cable to the PC
  • Open the command prompt
  • Change directory to the android SDK platform tools (Type in cmd--> cd C:\Program Files\Android\android-sdk\platform-tools)
Type following commands in cmd
  • adb devices (verify device is identified by pc. If not reconnect device and try again)
  • adb shell
  • adb reboot
It will restart.
Feb 12, 2014 | Android 4.0 Tablet PC
I have Problem with the Suunto Pc Pod Wireless Transmitter Driver for Suunto USB PC pod with windows 7...
I found out that this is because the wrong drivers are installed.
When you install the suunto software the usb drivers are stored under C:\Program Files\Suunto\USBDriver. This contains more than one driverset. See if you can find this.
Then go to Control Panel\Hardware and Sound\Devices and Printers and find your Suunto device. You probably have only one device and will miss Suunto Usb Serial Port.
Now open the deve and change the drivers, via manually select . Select browse and go to C:\Program Files\Suunto\USBDriver. Press Enter. The program will see that there is more than one driver set and offers you a choice.
Previously it has automatically selected the newest one, which unfortunately did not work in my case. Select the oldest set and the program will install the drivers,
Now you will see in Control Panel\Hardware and Sound\Devices that you have 2 devices suunto pc pod and suunto usb serial port. And the program will run and be able to connect to the watch
Good luck
Timco
Dec 13, 2010 | Suunto Pc Pod Wireless Transmitter
Attach DS3407 to PC
ø Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
?? Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
?? Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
?? Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
Dec 07, 2010 | Symbol DS3407 Barcode Scanner
Driver for Suunto USB PC pod with windows 7 64-bit
I had a problem with the drivers for W7 32 bit, maybe it's the same problem:
Good luck
Timco
Aug 02, 2010 | Suunto Pc Pod Wireless Transmitter
Its going upto veryfying username and paswrd level then its getting disconnected
he turnkey download contains a ready-to-use version of Tomcat (version 6.0.14) in which the the BlazeDS WAR file has already been deployed and configured along with a variety sample applications. The Flex 3 SDK has also been provided in this download for your convenience. The turnkey allows you to get up and running with BlazeDS in a matter of minutes. BlazeDS is licensed under GNU Lesser General Public License, Version 3. The Flex 3 SDK is licensed under the Adobe Flex SDK License Agreement and the Mozilla Public License, Version 1.1. Please refer to the Legal Stuff page for specific licensing informatiohe turnkey download contains a ready-to-use version of Tomcat (version 6.0.14) in which the the BlazeDS WAR file has already been deployed and configured along with a variety sample applications. The Flex 3 SDK has also been provided in this download for your convenience. The turnkey allows you to get up and running with BlazeDS in a matter of minutes. BlazeDS is licensed under GNU Lesser General Public License, Version 3. The Flex 3 SDK is licensed under the Adobe Flex SDK License Agreement and the Mozilla Public License, Version 1.1. Please refer to the Legal Stuff page for specific licensing informatiohe turnkey download contains a ready-to-use version of Tomcat (version 6.0.14) in which the the BlazeDS WAR file has already been deployed and configured along with a variety sample applications. The Flex 3 SDK has also been provided in this download for your convenience. The turnkey allows you to get up and running with BlazeDS in a matter of minutes. BlazeDS is licensed under GNU Lesser General Public License, Version 3. The Flex 3 SDK is licensed under the Adobe Flex SDK License Agreement and the Mozilla Public License, Version 1.1. Please refer to the Legal Stuff page for specific licensing informatiohe turnkey download contains a ready-to-use version of Tomcat (version 6.0.14) in which the the BlazeDS WAR file has already been deployed and configured along with a variety sample applications. The Flex 3 SDK has also been provided in this download for your convenience. The turnkey allows you to get up and running with BlazeDS in a matter of minutes. BlazeDS is licensed under GNU Lesser General Public License, Version 3. The Flex 3 SDK is licensed under the Adobe Flex SDK License Agreement and the Mozilla Public License, Version 1.1. Please refer to the Legal Stuff page for specific licensing informatiohe turnkey download contains a ready-to-use version of Tomcat (version 6.0.14) in which the the BlazeDS WAR file has already been deployed and configured along with a variety sample applications. The Flex 3 SDK has also been provided in this download for your convenience. The turnkey allows you to get up and running with BlazeDS in a matter of minutes. BlazeDS is licensed under GNU Lesser General Public License, Version 3. The Flex 3 SDK is licensed under the Adobe Flex SDK License Agreement and the Mozilla Public License, Version 1.1. Please refer to the Legal Stuff page for specific licensing informatiohe turnkey download contains a ready-to-use version of Tomcat (version 6.0.14) in which the the BlazeDS WAR file has already been deployed and configured along with a variety sample applications. The Flex 3 SDK has also been provided in this download for your convenience. The turnkey allows you to get up and running with BlazeDS in a matter of minutes. BlazeDS is licensed under GNU Lesser General Public License, Version 3. The Flex 3 SDK is licensed under the Adobe Flex SDK License Agreement and the Mozilla Public License, Version 1.1. Please refer to the Legal Stuff page for specific licensing informatiohe turnkey download contains a ready-to-use version of Tomcat (version 6.0.14) in which the the BlazeDS WAR file has already been deployed and configured along with a variety sample applications. The Flex 3 SDK has also been provided in this download for your convenience. The turnkey allows you to get up and running with BlazeDS in a matter of minutes. BlazeDS is licensed under GNU Lesser General Public License, Version 3. The Flex 3 SDK is licensed under the Adobe Flex SDK License Agreement and the Mozilla Public License, Version 1.1. Please refer to the Legal Stuff page for specific licensing informatiohe turnkey download contains a ready-to-use version of Tomcat (version 6.0.14) in which the the BlazeDS WAR file has already been deployed and configured along with a variety sample applications. The Flex 3 SDK has also been provided in this download for your convenience. The turnkey allows you to get up and running with BlazeDS in a matter of minutes. BlazeDS is licensed under GNU Lesser General Public License, Version 3. The Flex 3 SDK is licensed under the Adobe Flex SDK License Agreement and the Mozilla Public License, Version 1.1. Please refer to the Legal Stuff page for specific licensing informatio
Feb 14, 2010 | Vodafone Mobile Connect (055270) Wireless...
I want to make a softphone so plz give me the whole source code of softphone in php, vb.net, asp.net2.0 (any) languages.
You can find what you need here: http://www.filebuzz.com/findsoftware/Free_Source_Code_Soft_Phone/1.html
Now, admittedly, this was an easy search. I'm sure there are others, but I checked the DLs on this site, and they seem to be working fine - and without any bugs attached.
Jul 06, 2009 | Microsoft Excel for PC
Deploying App (Post Deployment Error)
Under Windows CE 4.x series:
Look under here:
Motorola EMDK for .NET\v2.0\SDK\Smart Devices\wce400\armv4
for symbol.all.arm.cab to copy to the PDA to install.
For Windows Mobile 5.x series:
Look under here:
Motorola EMDK for .NET\v2.0\SDK\Smart Devices\wce500\armv4i
Hopefully you won't get the error again. I personally just reference the dll under:
and have each symbol reference in my smart device deployment set to "local copy = true". Good day.
May 06, 2009 | Symbol MC9090 Barcode Scanner
I purchased the NEXTAR T30. i INSTALLED THE DRIVERS AND RESTARTED MY COMPUTER BUT IT STILL SAYS IT WILL NOT RECONIZE THE DEVICE. I AM RUNNING WINDOWS XP ANY ADVICE ON WHAT TO DO NEXT THAK YOU JEREMY
Many people sow the Nextar T30 as not being shown on their PC just as mine did. I found that, the USB port on the T30 is very very tight and even when you have the mini USB in enough to charge the device it doesnt always read it. You have to push the plug in until it snaps in place. You will see no metal on the mini USB plag showing at all once it is in all the way.
I first put the CD in that came with it, then I opened it and found the folder with the firmware update program and clicked on it to install because it also has the drivers. Once that was done I restarted my PC and then connected the USB plug in all the way until it snapped in place (be carefull could break it as it is too tight really). And now my player works every single time all of the time.
Hope this solves your problem like it did mine.
Aug 10, 2008 | Audio Players & Recorders
Symbol DS3407 Barcode Scanner Logo
89 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
