Question about Dishwashers
Kenmoor built in dishwasher
The washer is an old analog push button design, it works in all funtions except the water will not pump out after the wash cycle or rinse, I assume if the pumps water to wash then the pump is ok, what could cause this problem? Thanks
  • yadayada
    yadayada Oct 14, 2008
    Thanks wil l have my Dad try that.
  • 943 Answers
HI thanks for your question. check the hose where it goes into the sink drain, it could be clogged there.if not, clogged there. blow through that hose, to see if its clogged somewhere else. try that
Posted on Oct 13, 2008
Dishwasher will not start. All option buttons light up except the Start/Stop button and the cancel button. I have turn the power off and on but still no wash cycle. Inside float is clear and so is spray...
Hello, I am sorry that your dish washer isn't working. One of the biggest problems with these new dishwasher is they install the control on top of the door and the operational circuit board below the control panel. Inside the door is acceptable to moisture which creates all kinds of problems. It not the spray arm or the float, or the pump. it is where they put the circuitry to control the dish washing machine.
I hoping that all you will need is a push button control strip for this dish washer. moisture get in the micro switches and make them inoperable. These button in the control strip are hermetically sealed against moisture....for a while.
Remember, it depends on how long has the dishwasher been working and what will be the cost to repair your dishwasher. Dishwasher are really good for 10 to 12 years of service. I worked on a Kenmore that was 25 years old. I told the lady of the house it is time for a new dishwasher. I could have repaired it, but really it not worth it when it is this old. GB...stewbison
Sep 06, 2011 | Maytag Dishwasher
Dishwasher won't start KUDIO1ILBS
How old is this dishwasher that you are using? Is this under warranty
Apr 24, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Hello I'm looking for advise on my 11 year old dishwasher. It's a kenmore ultra wash model # 15812. The problem is that when you push the wash button nothing happens. The drain funtion still works and all...
Hello there:
To be honest with you i would first try these solutions and see if they work cause a new machine would cost a lot of money.
But if you can fix yours it would cost a lot less so plese try these solutions that i have provided below first ok?
If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jun 30, 2010 | Dishwashers
Kenmore 665.16032402 wont run
Hi
Thanks for using FixYa. If the light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | Kenmore 24 in. 16029 Built-in Dishwasher
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
Jan 27, 2009 | Viking Designer Series DFUD041 (Premium)...
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
My motto is "if it ain't broke, don't fix it.", but in this case we will make an acception. Check the inside of the washer for a float device sitting on the bottom. Floats can get stuck or bent over, make sure it goes up and down freely
Jun 28, 2008 | GE Nautilus 24" Built-in Dishwasher
Water not draining after last cycle
Arlo, sounds like your pump isn't working right. You should hear it pushing water about during the wash cycle. If not, check the filter screen on the unit first. Next, we'll have to talk about what to check ... pump motor or timer.
Dec 07, 2007 | Frigidaire 24 in. FDBS956CC Stainless...
Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Sep 16, 2007 | Kenmore 24 in. 15173 Stainless Steel...
Open Questions:
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
