Question about Lexmark Office Equipment & Supplies
  • ronaldgall38 Oct 13, 2008
    cann't uninstall said it is printing it isn't
  • 352 Answers
Hi, just pull the printer cable from the pc for now and try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
Posted on Oct 13, 2008
Not communicating
try to clear printing queue in both printer and cpu. Also try a different cable.
Feb 14, 2015 | Lexmark X1155 X1155 All In One Inkjet...
Error: Printer Error (3825) Published 04/17/2012 04:30 PM ' Updated 05/30/2012 11:48 AM ' Answer ID 46577
How do I resolve the error message "Printer Error" (code 3825) on my all-in-one printer? To resolve the error:
  1. Remove all paper from the paper tray(s).
  2. Disconnect the power cord from the printer.
  3. Wait 5 seconds, then reconnect the power cord.
  4. Reload paper in the paper tray(s).
  5. Try printing again.
Mar 12, 2014 | Office Equipment & Supplies
My Lexmark printer is saying its out of paper and theres paper in the feeder, please help!
Hey friend, you can try this one.
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Sep 01, 2011 | Lexmark X4650 InkJet Printer
My HP 5610xi is giving me the "Cartridge Error: Refer to the device documention. I've replaced the cartridge with three new ones and still get the error message. I re-loaded the printer drivers. Any...
It is hardware problem show it service center.just try with this thing but i m sure it is hardware problem,
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Have a good day
Dec 18, 2010 | HP Officejet 6310 All-In-One InkJet...
Printer not Printing
well this is the software issue till i can understand. to be sure that it is purely software issue try to copy from your printer itself and see if that is not the printer's fault.
if its not then:
Remove printer's USB cable from your computer
delete the Printer's Icon from your control panel/ system preferences> Printers and faxes/ printers
now uninstall the software of kodak and reinstall the the software from
after software installs then plug your printer back in and wait untill it get installed on your system
try to print it again and see if you can print
May 28, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper is jammed in fuser. Actually it is contact paper jammed in the fuser. (Don't ask).:0) While it was not a smart move, I am unable to "unjam" it. Any suggestions?
You'll be extremely lucky if your fuser is not ruined. Nevertheless, first you have to remove the fuser.
1) Open the cartridge door and lower the secondary door as when you change the cartridges.
2) Raise the fuser cover that is just below the LCD screen on the front of the printer.
3) The fuser sits right on top. Loosen two blue plastic screw-locks--one on each end of the fuser. Then, lift it straight up and out of the printer (be sure it is cooled off!).
4) Inspect the fuser rollers indside the fuser housing.
More than likely, the rollers will have the contact paper wrapped all around and stuck to them, since the fuser generates heat like an iron. Rotate the fusers main big gear to try and get the paper out. In the likely event you cannot remove it (without damage to the rollers), you can try using 97% or higher isopropyl alcohol on a lint-free cloth if you cann even reach the affected areas to remove it.
If all else fails, go online and look for a rebuilt fuser...much cheaper than a new original. You have my sympthies, and GOOD LUCK.
Kodak Easyshare Printer dock series 3 not printing full picture
throw out your printer and buy another brand. if you call18002356325 the call goes to manila and chances are you will be talking to some one who only speaks partial english and knows nothing about kodak products but will read to you from these internet instuctions that you just read !!! kodak has become a very anti-american company in so many ways!!!
Aug 04, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
When the LEDs start to flash, release
Continue button. The LEDs will continue flashing until only Error LED will be lit.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
POST is complete when fan noise and rollers stops.
After POST wait for 5 seconds
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
This is the procedure resetting the counter.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
Toner Low LED will be lit.
8. Cycle the power of the printer.
- Remove the power cable
- Wait for 5 seconds
- Plug the power cable back to the printer
- Power the Printer on
Feb 24, 2009 | Dell 1720dn Laser Printer
Canon thermal printer cp-330
search for canon cp-220. There is an explanation of the problem. Good luck.
Nov 27, 2007 | Canon CP-330 Thermal Photo Printer
Canon CP 220- HELP Here is site for your printer. Try unplugging (from the wall and computer)the printer for a few minutes let it clear out the memory etc. Or even download and install the latest drivers. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Canon CP-220 Thermal Photo Printer
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
