Question about Whirlpool Washing Machines
Water would not drain. looks like no electric to washer. fuses and plug checked ok
    Problem Solver:
  • 5 Answers
You blew a thermal fuse inside the dishwasher door. It needs to be replaced. If you have a continuity tester or ohm meter, you can check the fuse, but be careful because it is live house current. shut off electricity first.
Posted on Oct 13, 2008
  • Clif4949 Oct 13, 2008
    disregard my answer, I misread the question sorry
Have a Whirlpool Cabrio washer WTW6400SW3 went thru wash wash cycle, then started to drain water to go into rinse cycle. Half way thru draining, was a loud electrical pop in control area of washer and...
sounds like a shorted machine due to water or moister? In most case you had a fuse blow on the machine somewhat like a thermal shut off fuse, most likely located in the panel. if this is the case u need to find out what shorted it, how water or moister got in? You can also look at the control curcuit board and look for burned seized transistors or areas indicating a burned out board.
Feb 11, 2015 | Whirlpool Washing Machines
The pump housing could be clogged with food. You can sometimes Access the strainer from inside the dishwasher. If that looks ok you will need to look at pump below by removing the hose clamps and checking the pump intake. If all that looks good you could have a bad solenoid or pump.
Dec 28, 2014 | General Electric WHDSR316G Top Load Washer
I have a miele novotronic w 1930 front load washer that for all practical purposes appears dead. No lights, nothing . I checked the breaker and the fuse box that miele's use and dryer still functions...
Also look for a fuse on the board. Sometimes they put a simple fuse on the board that goes out and the repairman replaces it with a whopping bill to boot.
Nov 04, 2013 | Miele Novotronic W1930 Top Load Washer
Machine will not switch on
machines dealing with water are having problems with powerswitches,
the plastic hood covering the powerswitch might be broken and water might come in.
Best thing to do, take the machine apart and look for rusty or wetted parts that should be dry, electrical parts that is..
hoping to have helped you
Jan 31, 2013 | Karcher K2.26 Electric Power Washer
Washing machine has died and I dont know how to drain water from drum. HOTPOINT AQUARIUS EXTRA WMS38
hello get a bowl or bucket and position the drain hose a low as possible the water should drain out .as for the machine dying do you mean it's total dead if so check the fuse in the plug if ok then check the fuse inside the washer's power supply it's a glass type hope it helps
Mar 26, 2011 | Hotpoint Washing Machines
Whirlpool elite
You have a plugged drain. You are going to have to remove the front cover. That has screws holding it in place. Once removed you will see the drain line and you need to disconnect it. Be careful though it will be full of water. Once you get the water out. You will need to clean the drain and the filter. This will solve the problem. Make sure unit is unplugged during this time
Feb 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer is washing but is not letting water out
remove drain hose in back and make sure it is not plugged with hair. also there is a drain hole between the rubber seals in the front of the washer just inside the door that always seems to plug with hair. When you remove the drain hose make sure to look inside the hole where the hose connects to the washer.
hope that works!
Jul 30, 2008 | Kenmore Elite HE4 Electric Dryer
Washer will not leave the drain cycle
Press PAUSE/CANCEL twice to clear the display then
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
It's because of a Long Drain condition. If the drain time exceeds 8 minutes, the water valves are turned off the code is flashed.
But Note: After 4 minutes the "Sud" error is usually displayed, then 4 minutes later the error code is displayed.
Jan 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
