Question about HP DeskJet 6122 InkJet Printer
Cartridge carridge won't move
I just changed out the cartridges. The carriage is all the way to the right and won't move to the center. It sounds like it is caught on something. The paper and power light are flashing. Paper is in the tray but not jammed.
Please advise.
    Sergeant:
  • 352 Answers
Hi, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 13, 2008
Ink cartridge in Z705 will not move to center of carriage for changing when top is lifted Even though the Belt is moving. Help !!!!!!!!!!!.. >:( :( :'(
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this helps.
Oct 24, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Aug 30, 2011 | Lexmark X2600 InkJet Printer
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
Carridge jam error shown but no sign of any blockage
Hi
Try this to remove carriage jammed error. Turn off your printer and open the ink cartridge door. Then use your hand to move the cartridge from left to right and then move it from right to left. I believe the ink cartridge it jammed and needs to use your hand to free it freely.
I will helps you solve your problem.
Regards
Feb 15, 2011 | HP Photosmart A526 photo printer
Machine says out of color ink. when i open the front panel to see what number cartridge I need, the carrier hides in the right hand corner instead of coming to the center where I could remove it. I would...
Your cartridges are supposed to move all the way to the right. Please refer to this link for replacing the cartridges:
F4280 Cartridge Replacement
Your cartridges are HP 60 Black and HP 60 Tricolor. Here is a link for your supplies from HP:
HP F4280 Supplies
Thanks for using Fixya.
Oct 10, 2009 | HP DeskJet F4280 All In One Printer InkJet
How do i change carridge
Turn on the printer there is a door in the front right, the cartridge carriage will go to the right, take each cartridge down and out, reverse the procedure to install the new cartridges
Jul 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Carridge jam problem, please help me to fix this problem. it is a 6310 all-in-one printer.
THat happened to me while changing out a printer cartridge before the carriage had fully stopped. I was able to gently move the carriage over a little bit...
Mar 24, 2009 | HP Officejet 6310 All-In-One InkJet...
How to change a cartridge on c4345
Installing new cartridge:
Remove cartridges:
Nov 26, 2008 | HP Office Equipment & Supplies
Colour Cartridge
hi check your cartridge number are ok , clean the pin points of the cartridge and carridge pins of the printer if not works , try another cartridge if not works than may be carridge faulty , carridge data cable faulty, or logic card of the printer go to your service center or any repairing shop .
Mar 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
HP DeskJet 6122 InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
