Amilo Pro v2055 motherboard replacement
The charger slot on my Amilo Pro v2055 laptop had become loose and thus not able to charge the battery. I took it to a laptop repair shop and was told that it was a right off because I'd have to get the whole motherboard changed due to the charging component being bent too far back.
I wanted to know whether it is worth my time trying to pursue and fit a replacement motherboard and or if it will be more hassle than its worth? Or if there is another way around this? I don't want to have to replace my beloved laptop!
Thanks in advance.
  • gsk1985 Oct 14, 2008
    Thank you for your answers, i will look online for a replacement jack and see how that works.
  • JDTec
    JDTec May 11, 2010
    The Ac connector on your motherboard is loose and it can be re-soldered. Check to see if you can find a independent tech in your area that could do it, Much cheaper than a new motherboard.
    Joe
    Problem Solver:
  • 12 Answers
Either replace the dc jack or have it resoldered. That should fix the problem.
Posted on Oct 14, 2008
  • richard reyes Oct 14, 2008
    try ebay theyr real cheep thanks
Replace motherboard
Hello, its most likely the power jack burned out which is cheaper than putting in a new motherboard by a long shot. I do those repairs all day long for about $90. Hope this helps.
My Youtube channel
Live Technical Support
Mar 24, 2013 | Fujitsu Siemens Amilo Pro V2055 Laptop...
Key replacement
whole keyboard is replaced as a unit. Cost about $21 for the part.
Sep 25, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Chip very hot on motherboard and laptop will not boot.
well i had a amd chip that would get really hot and it would make the computer not boot up at all so i replaced it and it fixed the problem i was told it was about to go out so maybe this advice will help u good luck
May 26, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
AMILO pro v2055 Shuts down not long after starting up
Sounds like it could be a ram issue. Rule of thumb for blue screenis to check the ram first
Feb 13, 2009 | Fujitsu AMILO PC Laptops
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
Oct 06, 2008 | Computers & Internet
No power going to laptop charger working another laptop amilo pro v2055
All Laptops have their own specific chargers. You may be using the wrong one,or the charger has a broken cable.
Jul 15, 2008 | Computers & Internet
Amilo Pro V2055 power problem
the motherboard is damaged from the bend input you will need a new motherboard.
Apr 18, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Amilo Pro v2055 Sound very quiet
Go to control panel then sound and audio devices then speaker volume and see what level it is set on.
Nov 01, 2007 | Fujitsu AMILO Pro V1000 Notebook
Fujitsu AMILO Pro V2035 PC Notebook
If it's only 10 months old it is still within the manufacturers warranty, so do not touch or alter anything to do with the charger or battery, as even though the battery is seeming to be the fault, it is normally the motherboard charging point that is faulty or the motherboard not recognising the battery is connected.
May 02, 2007 | Fujitsu AMILO Pro V1000 Notebook
Computers & Internet Logo
1,045 people viewed this question
David Payne
David Payne
