I have Xerox Phaser 4500 and it is showing that need to relace the maintenance kit. I know how to replace it but need to know how to reset the page count. Please help somebodyI have Xerox Phaser 4500 and it is showing that need to relace the maintenance kit. I know how to replace it but need to know how to reset the page count. Please help somebody
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life
This is a lexmark based machine with IBM logo's 1 of the 2 options should get you squared away ---- Option 1 ---- To enter the Diagnostic Mode: 1. Turn the printer off. 2. Press and hold the Go and Return buttons. 3. Turn the printer on. 4. Release the buttons when "Performing Self Test" displays on the operator panel. This counter is reset by the servicer after a "80 Scheduled Maintenance" message displays (300K copies) and a maintenance kit is installed. To view the Maintenance Page Count: 1. Select Maintenance Count Value from the diagnostic menu. 2. Press Return to go to the previous menu. To reset the Maintenance Page Count to zero: 1. Select Reset Maintenance Count. Pressing Select causes the maintenance page counter to reset to zero. - Reset Maintenance Count Saved displays momentarily. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count screen. ---- Option 2 ----
Maintenance page count This counter is reset by the servicer after a 80 Scheduled Maintenance message displays (300K copies) and a maintenance kit is installed. To view the maintenance page count: 1. Select Maintenance Count Value from the Configuration menu. 2. Press Return to go to the previous menu. To reset the maintenance page count to zero: 1. Select Reset Maintenance Count from the Configuration menu. 2. Pressing Select resets the maintenance page counter to zero. Reset Maintenance Count Saved displays momentarily. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count screen.
To reset the maintenance page count to zero: 1. Select Reset Maintenance Count Configuration menu. 2. Pressing Select resets the maintenance page counter to zero. Reset Maintenance Count Saved displays momentarily. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count screen.
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays (300K copies) and a maintenance kit is installed. To view the maintenance page count: 1. Select Maintenance Count Value from the Configuration menu. 2. Press Return to go to the previous menu. To reset the maintenance page count to zero: 1. Select Reset Maintenance Count Configuration menu. 2. Pressing Select resets the maintenance page counter to zero. Reset Maintenance Count Saved displays momentarily. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count screen.
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
configuration page or a supplies-status page
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled Maintenance” message displays (300K copies) and a maintenance kit is installed. To view the Maintenance Page Count: 1. Select Maintenance Count Value from the Diagnostic menu. 2. Press Return to go to the previous menu. To reset the Maintenance Page Count to zero: Select Reset Maintenance Count. Pressing Select resets the maintenance page counter to zero. Reset Maintenance Count Saved displays momentarily. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count screen.
To enter the Diagnostic Mode: 1. Turn the printer off. 2. Press and hold the Go and Return buttons. 3. Turn the printer on. 4. Release the buttons when "Performing Self Test" displays on the operator panel. The tests display on the operator panel in the order shown: • Print Registration • Print Tests • Hardware Tests • Duplex Tests (If installed) • Input Tray Tests • Output Bin Tests • Base Sensor Test • Printer Setup • Error Log • EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Yeah, sadly that also goes by time. I don't know of a way to reset it. Other than replace the maintenance kit. I would suggest googling a business called The Parts Drop. Call and talk to Britt and see if he has the kit or even just the chip to replace to reset the count. You would want to make sure the large white roller is not dried out if you are just going to replace the chip. It is loaded with silicon lubricant that cleans and prepares the drum. If it is dried out, it will not be any good and the paper will tack to the drum.
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Lexmark MS811 dn maintenance count reset
how to reset page count samsung xpress c460w
