On 30 Jun 2004 04:03:37 -0700, georgette_ (Georgette
No, that's not the case, and you have no evidence to back that ludicrous statement.
GK
Was this helpful?
Yes
No
Solution #4
posted on May 27, 2006
Green1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
In article <>, Georgette
I've seen your "proof" of this claim. It is nearly as empty as your cranium seems to be, based on your behavior.
Was this helpful?
Yes
No
Solution #5
Grant - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Canon. Don't worry the 10D and the 1Ds are known to do the same with various lenses across all brands.
Was this helpful?
Yes
No
Solution #6
Mini Me - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Book says to R&R the battery.
Often it is a lens issue.
Look in on the dpreview 300D forum.
Phil
Was this helpful?
Yes
No
Solution #7
Ross - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
If you have another lens and only see the error on the kit lens, then it's likely the kit lens is at fault. Make sure the contacts are clean.
Was this helpful?
Yes
No
Solution #8
M0nica L - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I am usinmg the Canon kit lens and I did notice that taking the lens off and putting it back temporarily resolves the problem.
I'll try cleaning the contacts on the lens/camera body (non-abrasive, of course).
Thanks for the help.
-- Edgar B. Stephenson AT&T Internet Services Special Investigations & Legal Compliance
Was this helpful?
Yes
No
Solution #9
Powe33 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Yeah, yeah, search google & r&r battery clean contacts, etc.
Was this helpful?
Yes
No
Solution #10
Riddle - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I have heard that this could be a lens incompatibility. Try removing the battery pack and reinserting to see if it resolves the problem. Are you using Canon lenses or other brands such as Sigma?
When I try to view images on a tv the connection in the camera does not hold and the image does not...
(More)
When I try to view images on a tv the connection in the camera does not hold and the image does not stay. When I move the connection to a better connection and hold it the picture will stay if I put pressure on the the camera connection. Canon 30D
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly...
(More)
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly (running water no longer looks "frozen")...any ideas?
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or...
(More)
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or less) OK, so I figure the flash metering does not rely on the same mechanism. Anyone got a clue on how to get to the AE sensor? The location pepeik posted (thanks for that!) does not exactly suggest a way of getting there.
