Question about Aiwa XC-RW700 2-Disc CD Recorder
Aiwa XC-RW700 CD recorder
One day the unit would not power up when I pushed the on button. I'm assuming something in the power supply assembly is the culprit. Can I service this unit myself? I can't even find someone in my area that repairs electronic equipment. Whenever there's a problem, the mantra now-a-days seems to be throw it out and buy again. Any suggestions?
  • arch e Oct 17, 2008
    I have the same problem. if you open the metel cover up you can see a tube fuse next to the cord addapter. mines doesnt look blown. But either way i will have it tested or head on out to radio shack and buy a new fuse. best of luck to you.
3 Suggested Answers
jomabug76
  • 1148 Answers
SOURCE: problem copying from cassettes or vinyl.
CHANGE RCA JACKS ,,COULD BE A BAD ONE,, ALSO ,,TRY BLOWING IT OUT
Posted on May 15, 2009
dunnbiker
  • 8546 Answers
SOURCE: I cannot finalize my CD's
On page 18 of >>>> the manual <<<< it says to press the " > " key within 3 seconds after "Finalize". You wouldn't want a careless button push to just run off and close out the disc, would you?
Posted on Aug 04, 2011
Samsung LCD TV model number:LN40D550K1FXZC. No Back light problem. Audio works, Flash light test shows picture. i have changed the Back light inverter with no change.
You have to verify if there is power going in to the back light inverter. If there is power going in to it, check if there is power coming out. If no power is going in to the inverter work back to the source; most likely the main power supply area. It would be nice for you to have the shop service manual for the set if you are to spend some time on trying to fix it. You may need a scope to perform specific tests indicated in the manual.
If there is power leaving the inverter, then the problem and be the lamp assembly inside of the display. Depending on the model the display lights are not always serviceable.
Jan 25, 2017 | Samsung Televison & Video
No Image displayed
If you get no sound but the hum, there is a problem on the power supply panel inside this TV set. The only way to repair this set would be to replace the power supply panel. But before you condemn the power supply panel, open the set and disconnect the back-lite inverter supply and make sure that is not loading down the TV sets power supply. You would not see a picture if you disconnected the inverter circuit, but the sound should come on. Good Luck
Jun 30, 2007 | Fujitsu Plasmavision PDS-4233 42 in....
My aiwa dual deck player recorder keeps shutting off when playing I don't know the problem
Is it happening to both decks? Generally, it's usually the "take-up" drive belt. They all tend to stretch and dry out over time, so a complete belt renewal could restore proper function.
Jul 03, 2014 | Aiwa XC-RW700 2-Disc CD Recorder
When DVD is plugged in the red stand-by light comes on, but when the power button is pushed the stand-by light goes out and the DVD will not come on. I have attempted to reset by holding power button down...
Hi Erickson,
First of all, thank you for posting your question here at Fixya.
I'm assuming here that your unit is Sharp BD-MPC41U.
The symptoms you've mentioned indicated that the power supply board of your unit gone to protection mode that's why the LED automatically shuts off. It will encountered once the feedback circuitry sensed malfunction and immediately turned off the unit to avoid further damaged.
To resolve the issue, you have to replaced the power supply board, part number RUNTKA699WJN0. I saw it in stock at this LINK or obtain it from your local Sharp service centers.
Also, don't forget to check if your unit is under warranty period (1 year), if so, avail it because the manufacturer will fix it for free. Opening the top cover will void the warranty.
Please let me know if you need further assistance.
Hope I helped you!
Have a great Holidays!!!
Ratings and feedback are highly appreciated.
Jdvillanueva
Dec 25, 2011 | Sharp BDMPC41U Theater System
What is original remote control model number
The model # for the original remote is.
XCRW700
Sep 12, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
I cannot finalize my CD's on my Aiwa XC-RW700 Dual CD recorder might you know the problem? when I push the finalization button in blinks for a few seconds like it's going to finalize but...
Aug 03, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
When i turn my tv on it powers off after a few seconds
In the absence of audio and video, the likely culprit is the main power supply which services both. Plasma sets use an output of the main supply to produce the high voltage required by the plasma display which has attributes similar to the older CRT displays in the use of high voltage and internal phosphor to convert electron flow into light. The main supply may be a separate assembly. If you feel adventurous, pull the AC plug overnight and remove the back panel of the set. Look for a smaller board with fewer, but larger, components on it. There may be another separate smaller board that produces the high voltage for the display but it is probably OK but not receiving service voltage from the main supply.
If you can find an assembly number on the main supply, you may be able to buy or exchange it for a repaired unit and do the swap yourself.
Feb 09, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
Aiwa Dual CD Burner, cd's skip and sound scratchy
memorex and kyphermedia WON'T work in this recorder FYI Don't know what brand will
Jan 19, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
Aiwa XC-RW700 2-Disc CD Recorder Logo
118 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
