Question about VIA Computers & Internet
Transfering files via a serial cable from vista computer to satellite receiver
I cannot transfer downloaded files via a serial cable with usb adapter to my fta stb receiver.using a loader program from the receiver manufacturer website.the program stops at the point of loading the file.it says reset receiver and does not load file.the loaders were installed,used port #4 which works (usb)ports only on the computer serial and usb on the satellite receiver.the loader program always stops at the loading point(zmodem squint o% then locks up.i have to log off to stop, remove the loader program as i cannot close the program at that particular point.i need help to fix this problem please.oh the receiver has boot on the display panel and does not respond to remote control or manual pressing of the control nobs on the front panel.i have to turn power off from the back power button also.
  • skullbox Oct 13, 2008
    i have a viewsat vs pro free to air satellite receiver given to me by my american friend who is leaving for campus.i use a vista home basic computer,a second hand one, cannot afford to buy one i am very poor.cannot afford to pay you now sorry for taking up your valuable time on this project.god bless
    Master:
  • 538 Answers
To make this work we will need a ton more information from you..let us start with models of the other devices
Posted on Oct 13, 2008
How to Set Up the Kbox Pro Digy (FTA Receiver)?
-Extract files (factory bin & version bin)
http://www.abadss.com/forum/983-kbox...te-v2-0-a.html
-from remote, menu-config-system recovery & select delete all channels then factory reset
-insert USB into port in front of reciever, menu-utilities-data transfer-data download (from USB storage)-factory bin (version 1.81)
-menu-config,system recover y and select factory reset
-menu-utilities. data transfer, data download from usb storage-select latest bin (version 2.18)
-menu-config-system recovery-factory reset
-plug khub into reciever using black serial cable, also plug into network cable running to your router or switch
-from controller-menu-utilities-data transfer-data download from USB storage, then select khub activation
-menu-installation-options and make sure all AU options are set off and mode is set to network
-menu-installation-dish settings & config satellites you have setup dishes, then press red button on each satellite to scan in channels
-menu-config-network and change mode to DHCP press green button on remote and wait for it to be complete
-once previous step is complete, turn reciever off with remote, then from back. Wait 30 seconds, turn unit back on
Oct 20, 2016 | Video Game Consoles & Games
Where do I find a 6 pin serial to usb adapter for the Garmin 421s? I can't find one anywhere on line. Does Garmin sell one? It's Saturday and Garmin's help center is closed. Their on line...
The 6 pin DIN plug found on the GPSMAP 421s data/power cable (Garmin part number 010-10918-00) is used for the sonar input.
Data transfer from the GPSMAP 421s is easily transferred by memory card.
Information about data transfer on the 421s is at about 50 seconds into this video.
http://www.youtube.com/gpscity#p/search/6/8ddIgvCAUmI
Real time NMEA data can be transferred using Garmin part number 010-10918-00 wired to a DB-9 serial connector (Instructions are on the cable).
It then can be adapted to USB using a serial to USB adapter.
http://www.gpscity.com/gilsson-serial-to-usb-port-4in-adapter-for-pc-and-mac.html
Sep 17, 2011 | Garmin 421S GPS Receiver
What cable or adaptor do I need to transfer all data from the hard drive of my Toshiba Satellite Pro A200 via USB port? Thanks.
you do not need any special adapter or converter just use portable hard disk to take back up of data
seagate, transcend
Mar 14, 2011 | Toshiba Satellite Pro A200-EZ2204X...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
What wifi card for 12xl500 (compaq)?
It depends.
If your computer runs Windows XP or Windows Vista or Windows 7, every known brand-new wireless adapter will work.
If your computer has a PCMCIA slot (about the size/thickness of a credit-card), then you can buy a "PCMCIA wireless adapter".
If your computer has a USB slot (most do!) then you can buy a "USB wireless adapter".
There are three different data-transfer speeds for wireless communications:
* wireless B -- up to 11 megabits/second
* wireless G -- up to 54 megabits/second
* wireless N -- much faster.
Note that "high-speed" service from your local cable-modem ISP can receive at up to 10.0 megabits (or even faster) per second, while "lite-speed" service receives data at around 1.0 megabits per second.
So, when downloading, it's your cable-modem (or DSL-modem) that will be the "bottle-neck", not the "B" or "G" or "N" capability of your wireless adapter.
You probably can find "used" wireless-B or wireless-G adapters, in your local area:
* online, via 'www.usedEverwhere.com'
* local computer-stores
* online via eBay
for $10 to $20 dollars.
Pick a "brand-name", and you can download the device-drivers for it from the manufacturer's web-site ('www.linksys.com', 'www.dlink.com')
if Windows does not automatically recognize it.
Nov 25, 2009 | Compaq Computers & Internet
I have a belkin easy transfer cable. How do i transfer photo's
On the old computer, run Vista's "Files and Settings Transfer Wizard" to write one large file onto the old computer. The "export" file will contain your pictures.
Copy, via the transfer-cable, that one file to the new computer.
Run the "import" function of the Windows 7 Files and Settings Transfer Wizard to read the copied file.
Nov 17, 2009 | Dell Computers & Internet
USB data transfer from old to new computer
I answered you in another post, you need to network the computers via ethernet, not USB.
Jan 29, 2009 | Micro Innovations MCNCPQ5PHC USB PCI Card...
Com port missing?
check to see if the computer even has a serial port, most today dont have them and use USB instead. if this is the case, contact the receiver company to see if the have a usb version of the connection cable and software and download it and the manual for it. check to see if it needs a special cable as well while on the site. it might not need a special cable but it disent hurt to make sure.
Aug 04, 2008 | PC Connection Computers & Internet
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
Y-Modem file transfer aborts
Otie, Is this the only unit having trouble? Have you checked your firewall settings? Not knowing the error messege I will just throw my 2 cents in... Have there been any updates to the XP Pro? Has there been any ProComm updates that may have affected the machine. You may need to reset and reconfigure the modem. There could even be some kind of interference at the Telco Office. Just some thoughts, Tim
Feb 02, 2007 | Hawking (UC232S) Serial Adapter
Computers & Internet Logo
561 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
