Question about 2wire (1000-400108-001) Router
Connecting my router to my Directv DVR
Trying to hook up my dvr to the internet. It goes through all the motions but says there is no internet connection(22).Do I need to change my router to static and how do I do this.
If you are using an AT&T supplied 2-Wire router - then I have the same setup.
It does work.
First you can check to see if DHCP is doing the job.
Go to your router address:
(something like 192.168.1.254:5000) < they should have given you this on install)
Look at your network and see if the DVR is there.
If so, note the address.
Now go to setup on DVR and see if it has the same address.
If not...
You don't need to change the router to static, but it helps to change the DirecTV dvr to static.
I have the HR-20.
Give an address in the range of those leased by the router.
192.168.2.166 or something.
Make sure your first 3 octects match your router ie: 192.16.1
Just go to setup on the DVR and change it to the hard IP address.
If the router is not uPnP (2-Wire is not), then you may have to open a port or tow to get DirecTV VOD to work (maybe not or I don't remember which ones, googe it.)
The IP Mask should be 255.255.255.0.
Open the screen with the button below the lower DIrection Switch.
It is the you go for
'Find SHows'
"manage Recordings"
If you see a new entry entitled "Pictures, Vedeos and more" then you are online.
If not --- google some more.
Posted on Oct 19, 2008
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV Genie® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your Genie® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Feb 08, 2016 | Televison & Video
Does the Sanyo multimedia prod-III connect to direct tv
What are the DIRECTV TV Apps and how do I access them ...
https://support.directv.com/.../what-are-the-directv-tv-apps-and-...
DirecTVDIRECTV's FREE HD TV Apps are interactive features that let you do all of the below without missing ... How do I connect my Genie® or HD DVR to the Internet?Missing: sanyo ‎multimedia
Media Share - DirecTV
www.directv.com/DTVAPP/content/directv/.../mediashare
DirecTVYou can quickly browse thumbnail images or create a slideshow. ... Set up Media Share by connecting your DIRECTV Plus® HD DVR to your computer.Missing: sanyo
[PDF]Programming a DIRECTV Remote to Work With Your TV
manuals.solidsignal.com/directvrc64forweb.pdf
Jan 20, 2016 | Sanyo Office Equipment & Supplies
Have a DIRECTV mobile internet stick, which plugs into a USB port to have internet access. I want to make my internet access a wifi access. What do I need to do this ?
If you do not already have a wifi router you will need to purchase one, install it and connect your Directv receiver to it. If you do have already, you will have to go through the settings on your Directv receiver to setup a wireless connection.
How to connect your DIRECTV Plus HD DVR to your home Wi Fi network with...
Jul 30, 2013 | Linksys Wireless-G WRT54G Router
Powerline adapter wont work with directv dvr
Different modems have different configurations - your new provider should be able to assist you in getting connected.
Sep 14, 2017 | Powerline Ethernet Network Adapter
I m using TOPICA 16 chennal DVR How can I access this DVR on my PC
Depends on which side of the router the DVR is on. If it's inside(meaning no access from the internet) then type in the address of the DVR on a web brouser to see the video. If you are trying for internet access then you need to assign a port in the dvr setup. Then you must forward that port in the router so it can be seen from the internet.
Jun 14, 2012 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
Trying to connect to directv dvr for ON Demand services via ethernet cable, but directv dvr doesn't recognize connection
Run your DVRs outomated network setup.. If this fails, you will have to get the ip settings manually. to find them, use a computer that is connected to the router.. Do start, run, type cmd, press enter. In the black window that comes up type ipconfig /all this will give you the settings the DVR wants. choose manual setup from your DVRs network connection menu.
Sep 29, 2010 | 2wire (1000-400108-001) Router
How to configure 2 Linksys router and connect to Direct TV DVR on demand?
No configuration is necessary. Simply run a RG45 cable between the router and the DirecTV box. DirecTV will begin communicating immediately with the internet.
Oct 09, 2009 | Linksys WRT160N Wireless Router
I have a Samsung HLP5063wx xaa and I am getting a HDMI not supported when I hook up my HD-DVR, any help on how to resolve this, PLEASE!!!
I fixed it, if anyone is having this problem, you will have to tell your Directv box to only accept 720p resolution, I only have one line hooked up to my Hd-DVR right now and I had to tell the Directv box that it was on a Single tuner not Dual, I re-booted the directv box and everything works. I hope this helps anyone w/ an older model DLP, It took me hours on the internet to find the answers I needed.
Jun 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
Mar 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
2wire (1000-400108-001) Router Logo
4,200 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
