Question about Fisher and Paykel GWL11 Top Load Washer
Fisher pakel washer taking too long to wash clothes
I have a Fisher Pakel washer that is taking too long to wash the clothes. It takes 2 hours to 2 hours and 10 minutes to complete a cycle. My water pressure is fine going into the washer, I have cleaned the screens on the water lines and changed out the water lines to the washer. I have checked the black drain pipe to make sure it is only 3/4 of an inch past the u-shaped holder so that it is not siphoning off like the manual says. I called the company and they state it should take about 1 hour to complete the cycle.
Can you help?
  • RLCH Oct 17, 2008
    The same thing is happening to us. We've checked that the settings are for a normal wash load and the water flow is okay. The loads are taking 2 hours plus to complete a full cycle with a full load. I tried a small load to see if it helped, with the washer less than half full it took 1 hour and 32 minutes to complete. Is it time for a new washer?
My Fisher& Paykel GWL 10US was take way to long to washer 2+ hrs. The Solution was CLEANING SCREENS to hot and cold water valve. Don't get mad at the washer for something as easy as clogged screens. Over 10 years of almost perfect service!! (Change those Hoses once in awhile and save your self some grief)
Posted on Jun 19, 2013
    Problem Solver:
How long does it take to fill the tub? if the water, on warm stteting, isn't blasting out fast or if, when set to cold, it's trickling out, your cold water valve is shot. I can help with this problem 'cause I had the same experiences you listed.
Posted on Oct 20, 2008
Wont wash just flashes the wash light
most likely the controll board at the bottom has gotten wet due to accidentally overloading the washer.Remove the droor and dry out the board with a hair dryer.That is the most common cause of problems with the fisher pakel dish washers
Apr 06, 2014 | Fisher and Paykel GWL11 Top Load Washer
Replaced computer in fisher and pakel top loading washer and still does not work. what is wrong??
does it beep at you? is it dead? if some lights are on while it's beeping, they are an error code, can you relay them to me?
Oct 11, 2013 | Fisher and Paykel Washing Machines
Fisher and pakel washer keeps filling
Check the clear pressure tube for blockages, holes or has fallen off.
Apr 14, 2012 | Fisher and Paykel Washing Machines
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
When the washer is pumping water in it makes a noise like the pump is starving for water. I have checked water flow through the lines and the inlet filters ar not stoped up.
The only thing I've ever had to replace on that model washer is the pump, and they go out all the time. You have to order it from fischer and pakel directly, and it is extremely easy to replace (can do it with no tools at all) Remove the wires from the pump. Ther is a plastic tab that releases it so you can turn it. Turn it 1/4 turn and it will come out. To get a pump call 888-936-7872 (fischer and pakel customer care)
Nov 26, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher pakel washing machine is not draining or spinning what should I do?
The valve is stuck or dirt is in it. To fix blow in the drain hose of the washer about 3-7 psi enough to hear the air bubbles in the bottom of the tank, it might take more then one shot you can blow with the mouth but not with a air hose at 50 psi the valve and hose will not like it. It has always fixed mine, good luck. To check run in spin the last led red the water should run out.
Nov 17, 2009 | Fisher and Paykel GWL11 Top Load Washer
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher pakel water saver washer stopped early in cycle and is non stop beeping
www.ths.gardenweb.com/forum/laundry
try this website. I found answers to my questions on it that i did not find here.
repairman who came to my house yesterday said manuals are only available on dvd, not in paper anymore.
saw on the other website that you can order FP parts through Sears. have not tried, so don't know if that is reliable. maybe you can order a FP manual through Sears to tell you how to fix your issue.
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher n pakel won't drain
Pump Belt ?
Does The Timer Stop At Particular Position? If So, Timer Failure
Feb 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
351 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
